*EXTREME* Electric Malfunction - looking for wisdom & fix ideas
To start:
- I havent taken the car to Audi
- I havent checked fuses or relays
- Tree fell on the car- things were still working then. But then I brought it to a cheap bodyshop for work, and ever since I’ve been experiencing electrical issues— he said he left the car outside for a while. I’m fearing I may some sort of issues related to water damage in the rear.
Hopes:
- I hope I dont have to buy a new ECU or modules
- I hope I dont have to dissect the wiring.
Suspicions:
- After the first jump, My Alternator started acting up and died. Once I took the car for a ride, it died on me when I got to my destination and I needed another jump. Then I bought a new battery. I programmed it. While driving a few days later, had another notification of a dying alternator (not charging). I then dgot a jump, now its charging again, but I’m noticing, in some scans, the generator isnt performing and voltage regulator isn’t doing its job. So I hope some of these electrical issues are related to a bad charging system..?
Experiencing:
- First thing to go was my reverse camera
- After 4 months of not driving the car, I had go jump her back to life and ever since I lost a ton of functionality, but it seems to be random?
1. Climate Controls: I cant turn on the seat heaters. Cant sync the climate controls from driver tuning ****. I cant use the auto function. Cant change fan speed or fan direction. Cant turn climate controls off. However, temp tuning *****, circulation, front and real defrost (thank god), and AC Buttons still work. Random af.
also in that area, the Drive Select and TC buttons still work.
hazards still work.
airbag lights still work.
Push start button just started working again.
2. MMI: none of the corner select buttons work. Nav, Tel, menu and back buttons dont work, I
the car, radio, and media button works when they want to, spinning **** works & its central selector button works.
all window and convertible buttons work.
door locks do not work.
Blind spot assist does not work.
3. Steering Wheel: volume button works up and
down, but doesn't click mute. iNav button works. Voice control, mode, left side wheel & selector don’t work. Upshift paddle shifter works, but the downshift doesn’t. Map lights like to work intermittently— driver and right side passenger map lights turn on by themselves.
I also experienced my driver seat adjusting by itself— kinda scary. Lumbar still functioning normally. passenger side functions normally.
Any ideas?
here’s my OBD11 scan:
OBDeleven vehicle history log
Date: 2023-12-17 16:02:35
VIN: WAUWFAFH7EN006803
Car: REPTAR
Year: 2014
Body type: UNKNOWN
Engine: CPMB kW ( hp) l
Mileage: 148377 mi
Full scan
Control Units: 23
Fault count: 15
Control Units:
05 Keyless System
System description: BCM2 2.0
Software number: 8K0907064HP
Software version: 0641
Hardware number: 8K0907064GP
Hardware version: H13
Faults:
No trouble codes found
08 Air Conditioning
System description: KLIMA 3 ZONEN
Software number: 8K1820043T
Software version: 0123
Hardware number: 8K1820043T
Hardware version: H04
Faults:
06 Passenger Seat
System description: MEM-BFS
Software number: 8T0959760E
Software version: 0076
Hardware number: 8T0959760E
Hardware version: H10
Faults:
36 Driver Seat
System description: MEM-FS
Faults:
42 Driver Door
System description: TSG FA
Software number: 8T0959793P
Software version: 0305
Hardware number: 8T0959793G
Hardware version: H09
Faults:
62 Rear Left Door
System description: TSG HL
Software number: 8T0959795F
Hardware number: 8T0959795F
Hardware version: H08
Faults:
72 Rear Right Door
System description: TSG HR
Faults:
17 Dashboard
System description: KOMBIINSTR.
Software number: 8T0920984N
Software version: 0564
Hardware number: 8T0920984N
Hardware version: H35
Faults:
46 Comfort System
Faults:
47 Sound System
System description: DSP Prem
Software number: 8F1035223A
Software version: 0030
Hardware number: 8F1035223A
Hardware version: H05
Faults:
02 Transmission
System description: 0BK 20TFSIUSA
Software number: 8K0927158T
Software version: 1005
Hardware number: 0BK927156AL
Hardware version: H16
Faults:
3C Lane Change Assistant Right
System description: SWA Master
Software number: 8T0907566B
Software version: 0071
Hardware number: 8T0907566B
Faults:
52 Passenger Door
System description: TSG BF
Software number: 8T0959792P
Hardware number: 8T0959792G
Faults:
00920 - Heated outside mirrors
static
priority - 3
frequencyCounter - 1
drivingCycle - 123
km-Mileage - 238726 km
date - 2023-12-16 23:40:13
5F Multimedia
System description: H-BNT-NA
Software number: 8R1035746E
Software version: 0756
Hardware number: 8R1035746D
Hardware version: H41
Faults:
02067 - Optical data bus unauthorized awakening request
Intermittent
priority - 6
drivingCycle - 163
date - 2023-12-16 14:03:57
03157 - Function restriction due to communication interruption
Intermittent
priority - 6
frequencyCounter - 2
drivingCycle - 163
date - 2023-12-16 15:49:19
01524 - Antenna for telephone
static
priority - 7
drivingCycle - 123
date - 2023-12-16 01:22:28
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063DJ
Software version: 0103
Hardware number: 8K0907063DJ
Faults:
01856 - Right front seat temperature sensor
static
priority - 2
drivingCycle - 123
date - 2023-12-16 01:20:40
01855 - Left front seat temperature sensor
static
priority - 2
drivingCycle - 123
00979 - Right low beam headlamp bulb
static
priority - 2
drivingCycle - 123
date - 2023-12-16 01:20:41
16 Steering Column
System description: Lenks.Modul
Software number: 8K0953568Q
Software version: 0003
Hardware number: 8K0953568Q
Hardware version: H03
Faults:
02071 - Local data bus
Intermittent
priority - 3
frequencyCounter - 5
drivingCycle - 40
date - 2023-12-16 15:09:11
26 Roof Control
System description: VSG-AUDI-B8
Software number: 8F0959255
Software version: 0190
Hardware number: 8F0959255
Hardware version: H12
Faults:
19 Gateway
System description: GW-BEM 5CAN-M
Software number: 8R0907468P
Software version: 0056
Hardware number: 8R0907468D
Hardware version: H11
Faults:
02873 - Rearview camera system control module
static
priority - 2
drivingCycle - 123
date - 2023-12-16 01:21:04
00384 - Optical data bus
Intermittent
priority - 5
drivingCycle - 163
date - 2023-12-16 14:07:30
15 Airbag
System description: AirbagVW-AU10
Software number: 8F0959655E
Software version: 0430
Hardware number: 8F0959655E
Hardware version: H14
Faults:
53 Parking Brake
System description: EPB-4
Software number: 8K0907801M
Software version: 0004
Hardware number: 8K0907801J
Hardware version: H01
Faults:
56 Radio
System description: Radio U SIRIU
Software number: 4G0035082G
Software version: 0133
Hardware number: 4G0035082
Hardware version: H60
Faults:
00856 - Antenna, on radio
static
priority - 5
drivingCycle - 123
date - 2023-12-16 01:22:07
44 Steering Assistance
System description: RCEPS
Software number: 8K0909144F
Software version: 0507
Hardware number: 8K0909144B
Hardware version: H39
Faults:
U140A00 - Terminal 30
Open circuit
Intermittent
Priority - 6
Malfunction frequency counter - 1
Unlearning counter - 163
Engine speed - 0.00 1/min
Vehicle speed - 0.00 km/h
Supply voltage, terminal 30 - 12.36 V
Output stage voltage - 12.36 V
Factor reduction steering support UNT - 0.00
Voltage ASC DCLink ref hex - 60E0
Voltage ASC DCLink ref - 2.50 V
date - 2023-12-16 17:48:53
01 Engine
System description: 2.0l R4/4V TF
Software number: 8K5907115N
Software version: 0005
Hardware number: 8K2907115L
Faults:
P068A00 - ECM/PCM Power Relay De-Energized Performance - Too Early
Intermittent
Priority - 2
Unlearning counter - 255
Normed load value - 0.0 %
Vehicle speed - 255 km/h
Coolant temperature - 9 °C
Intake air temperature - 9 °C
Ambient air pressure - 1020 mbar
Voltage terminal 30 - 12.415 V
Dynamic environmental data - 209627107A0011BD09D9133806121610AB151403126EFFFF10 100000
P008800 - Fuel Rail/System Pressure - Too High
Intermittent
Priority - 2
km-Mileage - 238727 km
Engine speed - 829.50 1/min
Normed load value - 11.8 %
Vehicle speed - 45 km/h
Coolant temperature - 58 °C
Intake air temperature - 5 °C
Voltage terminal 30 - 14.088 V
Dynamic environmental data - 209628107A0311BD0B7D13380512160298151404126EFFFF10 100114
date - 2023-12-16 23:43:07
Intermittent
Priority - 2
Malfunction frequency counter - 4
Engine speed - 2037.00 1/min
Normed load value - 45.9 %
Vehicle speed - 55 km/h
Coolant temperature - 27 °C
Intake air temperature - 4 °C
Voltage terminal 30 - 13.947 V
Dynamic environmental data - 209628107A0311BD0B0B13380612160E11151404126EFFFF10 1007E2
date - 2023-12-16 23:41:49
Hopes:
Suspicions:
Experiencing:
hazards still work.
Any ideas?
Car: REPTAR
Year: 2014
Body type: UNKNOWN
Mileage: 148377 mi
Full scan
Control Units: 23
Fault count: 15
Control Units:
05 Keyless System
Faults:
08 Air Conditioning
Faults:
06 Passenger Seat
Faults:
36 Driver Seat
Faults:
42 Driver Door
Faults:
62 Rear Left Door
Faults:
72 Rear Right Door
Faults:
17 Dashboard
Faults:
46 Comfort System
Faults:
47 Sound System
Faults:
02 Transmission
Faults:
Faults:
52 Passenger Door
Faults:
static
priority - 3
drivingCycle - 123
5F Multimedia
Faults:
Intermittent
priority - 6
drivingCycle - 163
Intermittent
priority - 6
drivingCycle - 163
static
priority - 7
drivingCycle - 123
Faults:
static
priority - 2
drivingCycle - 123
static
priority - 2
drivingCycle - 123
static
priority - 2
drivingCycle - 123
16 Steering Column
Faults:
Intermittent
priority - 3
drivingCycle - 40
26 Roof Control
Faults:
19 Gateway
Faults:
static
priority - 2
drivingCycle - 123
Intermittent
priority - 5
drivingCycle - 163
15 Airbag
Faults:
53 Parking Brake
Faults:
56 Radio
Faults:
static
priority - 5
drivingCycle - 123
Faults:
Open circuit
Intermittent
Priority - 6
01 Engine
Faults:
Intermittent
Priority - 2
Intermittent
Priority - 2
Intermittent
Priority - 2
Ant Pacc
04-19-2023 04:36 PM
Audi.of.arabia
03-16-2023 09:05 PM
sydbloke
12-11-2022 03:41 AM
hudsonparker14
37
08-11-2019 06:24 PM
tt1234
46
04-24-2019 09:50 AM
