Parking Brake Malfunct Error, Air Bag Light. Help with diagnosing? VCDS Log Attached.
My 09 S5 started throwing these errors after I changed the air intake filter and cabin filter on my car. It seems unrelated to the errors, but I'm pretty sure I got these errors right after or maybe within a day or two. This was about 2 months ago.
I've copy pasted the log below. There seems to be a bunch of other errors too, maybe resetting the system would get rid of them, but I wasnt sure how to. I've only recently started use the Ross Tech tool.
I have some aftermarket parts and tune, which I doubt maybe causing some of these, but the car runs and drives fine. and I'm mostly trying to fix the parking brake malfunction and airbag light on the dash.
My initial search about the parking brake malfunc returned that the parking brake switch maybe faulty. This has happened to people who have taken apart the shift boot panel. I did too, a couple of months ago to switch out the shift ****.
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 15 16 17 19 36 42 46 47 52 53 55 56 65 77
VIN: WAURV78T59A006770 Mileage: 157640km-97952miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUB) Labels: None
Part No SW: 8T0 907 560 UM HW: 8T0 907 560
Component: V.6 JHM H10 0003
Revision: 76H10---
Coding: 01140009180F0120
Shop #: WSC 43231 000 1048576
VCID: 196FC9BC09906D93B5D-804C
1 Fault Found:
004898 - Knock Sensor 3 (G198)
P1322 - 001 - Signal too Large - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 157416 km
Time Indication: 0
Date: 2008.02.09
Time: 14:43:45
Freeze Frame:
RPM: 2846 /min
Load: 26.7 %
Speed: 114.0 km/h
Temperature: 97.0蚓
Temperature: 21.0蚓
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 110500
Shop #: WSC 06325 000 00000
VCID: 79AFE93CE9D08D9315D-802C
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 125
Mileage: 152555 km
Time Indication: 0
Date: 2020.10.06
Time: 09:45:35
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x40A2
Hex Value: 0x0013
Hex Value: 0x02A9
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 289 F HW: 8K0 907 289 F
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 0B0000
VCID: 3C213028A66278BB4EB-8068
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H34 0050
Serial number: 0107000112197002
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000011404003
No fault code found.
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001106702
Coding: 00017025002C00000000
VCID: 42DD4ED0C4860E4B047-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0123.06.080043
Coding: 48022000
VCID: 72BDDE10B4A6FECB547-8026
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 157
Mileage: 157330 km
Time Indication: 0
Date: 2008.02.08
Time: 00:01:56
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000167390
Coding: 26001091063CAF010000080300003D3D0F1C13880001016100 0000
VCID: 303914187A2A8CDBE23-8064
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280608 H13 0040
Serial number: SWFBIE 0000060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10165662
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Serial number: 00000000002606080808
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD125LP9
Coding: 303333333730303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3D273D2CBDF871B3795-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0800000X7V
9 Faults Found:
9437210 - Igniter for Driver's Airbag
B1000 1A [137] - Resistance Too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 157334 km
Date: 2008.02.08
Time: 02:25:27
9443113 - Driver's Side Airbag Crash Sensor
B1017 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Mileage: 153142 km
Date: 2020.10.14
Time: 15:18:36
9451049 - Crash sensor side airbag; passenger side
B1036 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 58
Mileage: 152578 km
Date: 2020.10.08
Time: 06:36:51
9443881 - Driver's Front Airbag Crash Sensor
B101A 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 137
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9444137 - Front Passenger's Front Airbag Crash Sensor
B101B 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 127
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9443369 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 113
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9443625 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 29 [137] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
13635840 - Supply voltage
U1011 00 [009] - Voltage too Low
[Powersupply lower threshold fall short of]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 119
Reset counter: 165
Mileage: 152578 km
Date: 2020.10.09
Time: 07:13:32
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
[Electronic Control Unit Malfunction]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Mileage: 155269 km
Date: 2020.10.30
Time: 20:24:46
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HFQ000DK
Coding: 000016
VCID: 3D273D2CBD7871B3795-8068
Component: E221 - MFL H02 0003
1 Fault Found:
00889 - Horn (H)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 157
Mileage: 157330 km
Time Indication: 0
Date: 2008.02.08
Time: 00:45:10
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 E HW: 8T0 920 981 E
Component: KOMBIINSTR. H30 0221
Revision: 00000000 Serial number: 97S53NY68
Coding: 8B1501000300D705020000
VCID: 3E253A20B07E6AAB60F-806A
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0861982BA
Coding: 000303
VCID: 46D552C0E8AE326B28F-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18028E0A130608
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 125
Mileage: 152578 km
Time Indication: 0
Date: 2020.10.09
Time: 07:51:52
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001106919
Coding: 00197325002C00000000
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 152578 km
Time Indication: 0
Date: 2020.10.09
Time: 09:11:06
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: C 8
Coding: 011C03224E002201
VCID: 7DA7FD2CFDF8B1B3395-8028
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00003002 Serial number: 0110418479
Coding: 0106029A007A444400B000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000037724
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Serial number: 0123456789ABCDEFGHIJ
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 131446 km
Time Indication: 0
Date: 2019.12.02
Time: 12:01:23
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 131446 km
Time Indication: 0
Date: 2019.12.02
Time: 21:33:27
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C03224000120102
VCID: 52FD7E9014E69ECBB47-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000159896
Shop #: WSC 00000 000 00000
VCID: 313F111C712085D3EDD-8064
3 Faults Found:
01321 - Control Module for Airbags (J234)
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 152555 km
Time Indication: 0
Date: 2020.10.06
Time: 09:45:35
Freeze Frame:
Voltage: 14.00 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
03200 - Switch for Electric Parking Brake (E538)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 82
Reset counter: 231
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.70 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x0160
Hex Value: 0x0008
Hex Value: 0x0101
02442 - Function Lamp in Control Head
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 179
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.70 V
Count: 72
Speed: 0.0 km/h
Hex Value: 0x0170
Hex Value: 0x0008
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 343118088232B0FB86B-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1027016
Coding: 050300020104850043D9070001
VCID: 40D944D8CA8A1C5B123-8014
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 143130 km
Time Indication: 0
Date: 2008.02.28
Time: 09:36:01
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 12926781248728
Coding: 0CD154
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 A HW: 8T0 862 336 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005004396
Coding: 0010370
VCID: 392F293CA5504D9355D-806C
Revision: 76H10---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 157416 km
Time Indication: 0
Date: 2008.02.09
Time: 14:43:45
Freeze Frame:
RPM: 2846 /min
Load: 26.7 %
Speed: 114.0 km/h
Temperature: 97.0蚓
Temperature: 21.0蚓
Voltage: 14.224 V
Coding: 110500
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 125
Mileage: 152555 km
Time Indication: 0
Date: 2020.10.06
Time: 09:45:35
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x40A2
Hex Value: 0x0013
Hex Value: 0x02A9
Hex Value: 0x00FF
Revision: 00003002
Coding: 0B0000
Coding: 48022000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 157
Mileage: 157330 km
Time Indication: 0
Date: 2008.02.08
Time: 00:01:56
Coding: 00FD11
Coding: 02532C
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 157334 km
Date: 2008.02.08
Time: 02:25:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Mileage: 153142 km
Date: 2020.10.14
Time: 15:18:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 58
Mileage: 152578 km
Date: 2020.10.08
Time: 06:36:51
Freeze Frame:
Fault Priority: 2
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
Freeze Frame:
Fault Priority: 2
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
Freeze Frame:
Fault Priority: 2
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
Freeze Frame:
Fault Priority: 2
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
Freeze Frame:
Fault Priority: 2
Reset counter: 165
Mileage: 152578 km
Date: 2020.10.09
Time: 07:13:32
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Mileage: 155269 km
Date: 2020.10.30
Time: 20:24:46
Coding: 000016
1 Fault Found:
00889 - Horn (H)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 157
Mileage: 157330 km
Time Indication: 0
Date: 2008.02.08
Time: 00:45:10
Coding: 000303
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 125
Mileage: 152578 km
Time Indication: 0
Date: 2020.10.09
Time: 07:51:52
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 152578 km
Time Indication: 0
Date: 2020.10.09
Time: 09:11:06
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 131446 km
Time Indication: 0
Date: 2019.12.02
Time: 12:01:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 131446 km
Time Indication: 0
Date: 2019.12.02
Time: 21:33:27
Cannot be reached
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 152555 km
Time Indication: 0
Date: 2020.10.06
Time: 09:45:35
Freeze Frame:
Voltage: 14.00 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 2
Fault Frequency: 82
Reset counter: 231
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.70 V
Count: 38
Speed: 0.0 km/h
Hex Value: 0x0160
Hex Value: 0x0008
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 179
Mileage: 1048574 km
Time Indication: 0
Freeze Frame:
Voltage: 12.70 V
Count: 72
Speed: 0.0 km/h
Hex Value: 0x0170
Hex Value: 0x0008
Hex Value: 0x0101
Coding: 0000002
Component: Display
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 143130 km
Time Indication: 0
Date: 2008.02.28
Time: 09:36:01
Coding: 0CD154
Coding: 0010370
Definitely appears the vehicle has been in an accident but if not then other issues. How old is your battery? Measure the voltage on your battery after it sits overnight or go and have it load tested then clear all codes, drive it and check it again to see what remains.
I am going to reset the codes, and see what comes back on.
Based on suggestions on other forums, it maybe the airbag module that needs to be replaced.
Mike Freeman
13
10-29-2020 03:17 AM
Jessyjey
S4 (B8 Platform) Discussion
09-24-2020 10:17 PM
WODT-Sanders
4.2 V8 Discussion
06-15-2019 07:46 PM
