2022 RS5 Wheel Fit? - 19x9.5 ET50
I've searched this forum and the google machine and haven't found a good answer. I have a chance to pick up a set of Rays VR.G2's that are 19x9.5 ET50 off of a TT. However, I'm not sure how close that offset and rim width will put the wheel to anything on the inside - suspension, inner wheel well, etc. I used willtheyfit and it looks like I'll be running 38.7mm closer. I don't want to run spacers. Tires will be stock size - 19/265/35.
Anyone know for sure if they'll fit without rubbing anything?
I think the 2019 RS5 Coupe offset is around ET26?
I don't think an offset of ET50 would fit.
The 2022 RS5, offsets seem to be ET22.
Look up stock wheel dimensions here: https://www.hubcaphaven.com/c/5564/a...eels_rims.html
yeah those won't fit without big spacers. the offset is way to high for this platform.
More so, they're from a TT. The VW clone Audis (A3, TT, Q3) still use the VW center bore, 57.1mm. Unless those aftermarkets were not made hub centric and have a large open center.
They're listed with a 66.5 center bore. But yeah, I figured the offset would be too much. Thanks for the quick replies, everyone! You saved me an eBay mistake.
B6_Dolphin (02-12-2024)
chicago_audi_dude
12-19-2005 10:05 AM
Lightweight-USPowah
12
07-31-2003 05:53 AM
