Disable Auto/Stop w/VCDS
#11
Here is the description if you just want to search:
For Audi A4 B9 2015-2020 A5 B9 A3 8V Q5 FY Car Automatic Stop Start Engine System Off Device Control Sensor Plug Accessories
#12
Club AutoUnion
Anyone who has coded this out — is my assumption correct t?
— John
#13
I “coded” the *** out with the OBD Eleven about 2 years ago and it’s worked flawlessly ever since, even when I have turned the AC off — but I think the way the coding works on the OBD Eleven system is even when I have disabled the AC via the environmental control button, the ODB Eleven codes have the compressor running. Again, I Think but I’m not stating this as a fact. And using the OBD method does not turn the *** LED on.
— John
— John
The aftermarket harness that is the item in this thread and video do not require coding, illuminates the start/stop button in the center control panel indicating it is off, and you can still reactivate start/stop if you wanted to via the button press. It's the reverse of the factory setting and is the most OEM way to do it without touching anything else on the vehicle.
Using the aftermarket harness is attractive to me because if I am idling in a parking lot with the A/C running and start/stop is running, the engine only turns on to run the A/C compressor to maintain my desired temperature and then the engine turns back off. With the OBD11 and VCDS coding, this is not possible because the climate control is on (fan is ON and/or AC is ON).
Nikon1 (08-31-2020)
#14
I’m going to guess, but am fairly certain, that the control box closes the contact wires going to the switch for a moment a few seconds after power up. It’s just like pressing the button yourself, but the little box does it for you. Ingenious.
A guy on the internet has been selling a gadget like this for some domestic cars for a couple years. In the case of Chevy the stop/start won’t activate if you’ve have the hood open. So you put his box in the hood wiring. It pulses the hood open switch at start and then the start/stop won’t activate while you drive.
#15
Club AutoUnion
@Daaavid — For me, I don’t think I’d ever re-enable the start / stop. This is strictly my opinion, but for the (potential) gas savings versus the (potential) wear and tear on the starter from *** being on, it’s just not worth it.
Again — IMHO
— John
Again — IMHO
— John
#16
This looks like a very good solution to *** which I find to be asinine to begin with, plus it come with the two removal keys. Seems like a gift from the Audi gods.
#17
Another nice feature as you say. I don't need the AC to always be on so not really a fan of the OBD11 solution. Looks like this is going to be a really good fix for ***...easy, inexpensive and from the video above an Audi part. The only negative is waiting 3 weeks for the part to arrive, and remembering to hit the *** switch, ha!
#20
There are 6 switches and only 5 wires so I would guess the module for the switches is connected using a CAN bus and the control box sent the proper message (*** switch pressed) a few seconds after power up.
