2009 MMI vs. 2010 3G MMI (reverse camera question)
Does the 2009 A5 coupe with Nav have the guide lines displayed on the screen when in reverse? (So you can see where the car is pointed based on steering angle) I know the 2010 model with 3G MMI does. Just curious...anyone with a 2009 coupe and MMI care to chime in?
Just to clarify, I can't speak with certainty for 2009 but for 2010 the reverse camera is included with the Navigation Plus package on the Premium Plus model, and, although navigation is standard on the Prestige model, you must select the Driver Assist package to get the reverse camera on a prestige. (Driver Assist also includes the Blind Spot warning system which flashes a yellow led on the inside of the side view mirros if you turn on a turn signal while someone is in your "blind spot")
Thanks everyone. This is a cool feature and I would like it on the car I'm about to buy so I just wanted to verify that the '09s have this feature included with the Nav/backup cam. Sounds like it does
Personally it's just easier to turn your head sometimes.
The parallel park feature is great to figure out if the potential space is large enough. The blue rectangle should be completely inside the potential curb space to ensure a proper fit.
So it is just there to tell you there is enough room to park? I thought it was like a target to guide you in, but then nothing moves with the steering wheel so I gave up.
tiger4366
05-22-2009 03:17 PM
