2014 Audi A5 Brilliant Red Chestnut Black roof Cab
#41
So, I ended up painting the side mirrors glass back to match the gloss black door blades. Wrapping the mirrors was a bit of a pain for me, I watched so many videos but I found it a bit of a pain to smooth out the air bubbles. Here is a before shot of red side mirrors and no door blades
![Name: M4.jpg
Size: 95.7 KB](https://www.audiworld.com/forums/attachments/audi-a5-s5-rs5-coupe-cabrio-b8-125/83439d1501529747-2014-audi-a5-brilliant-red-chestnut-black-roof-cab-m4.jpg)
After shot with gloss black door blades
![Name: M2.jpg
Size: 50.5 KB](https://www.audiworld.com/forums/attachments/audi-a5-s5-rs5-coupe-cabrio-b8-125/83440d1501529747-2014-audi-a5-brilliant-red-chestnut-black-roof-cab-m2.jpg)
After shot gloss black side mirrors ( sorry it rained last night, so the mirrors have rain marks on them, but u get the idea)
![Name: M3-1.jpg
Size: 76.8 KB](https://www.audiworld.com/forums/attachments/audi-a5-s5-rs5-coupe-cabrio-b8-125/83441d1501529747-2014-audi-a5-brilliant-red-chestnut-black-roof-cab-m3-1.jpg)
After shot with black door blades and side mirrors
![Name: M1.jpg
Size: 88.7 KB](https://www.audiworld.com/forums/attachments/audi-a5-s5-rs5-coupe-cabrio-b8-125/83442d1501529747-2014-audi-a5-brilliant-red-chestnut-black-roof-cab-m1.jpg)
Before / after comparison
![Name: M5.jpg
Size: 58.7 KB](https://www.audiworld.com/forums/attachments/audi-a5-s5-rs5-coupe-cabrio-b8-125/83443d1501529747-2014-audi-a5-brilliant-red-chestnut-black-roof-cab-m5.jpg)
... I like the black side blades, but i think i prefer the way the mirrors looked before. ( I might paint this back, this was a trial error project )
![Name: M4.jpg
![Name: M2.jpg
![Name: M3-1.jpg
![Name: M1.jpg
![Name: M5.jpg
#42
Forgot to mention, I paid $280 for the door blades, used off ebay, older S5. I had them painted and installed with 3M double sided glue (Pepboys $9.99 for a 5ft strip) and bolted on with like on an S5. I stopped by the Dealership to check how they are mounted. On A5, they appear to be just glued on, but on the S5, they are bolted on with a plastic clip. I purchased 9 clips for $2.70 each at the dealer, and drilled holes to the lower panel of my car, bolted, and glued the blades, like on an S5. Paint and installation was $150 for both. In all I paid $280+$150+$27+$9.99 (clips) $467 approx for door blades. Dealer wanted $920 for new blades and installation. Paid $125 to have mirrors painted. Dealer wanted $250.
#43
Re: 2014 Audi A5 2.0 AWD with 9700 Miles
Last night while driving home late night, orange warning light "ECP" came on. I could feel my car sort of jerking as I accelerated. I drove 30 miles home, but as I got close to home, I could smell gasoline, and a lot of fumes coming from the exhaust.
Today I connected VAG COM. this is what the printout looks like...
Part seem to indicate Ignition coil, and something else.
Has this happened to anyone else?
Does anyone know if this is covered under warranty?
Sunday,24,August,2014,14:33:22:04118
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAULXXXXXXXXXXXX License Plate: XXXXXXX
Mileage: 15670km-9736mi Repair Order: Repair1
Chassis Type: FH (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 36 42 44 46 52 53 56 5F
62 6C 72
VIN: WAULXXXXXXXXXX Mileage: 15670km/9736miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (DET-CPMB) Labels: 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 J HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0002
Revision: ECH09---
Coding: 622A0013242600062000
Shop #: WSC 29698 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115J 001003
ROD: EV_ECM20TFS0118K5907115J.rod
VCID: 3979DC81B84984D69C9-806C
8 Faults Found:
10426 - Fuel Pressure too Low during Cold Start
P053F 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:55
2838 - Fuel Rail/System Pressure
P0087 00 [175] - Too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:59
4601 - Cold Start Idle Air Control System
P050A 00 [101] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:08
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10591 - Cylinder 1
P0301 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:00
10593 - Cylinder 3
P0303 00 [175] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10594 - Cylinder 4
P0304 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:53
10205 - Cylinder Disabling
P130A 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:57
Readiness: 0000 0000
62 6C 72
Revision: ECH09---
8 Faults Found:
P053F 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:08
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10591 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:00
10593 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10594 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:53
P130A 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:57
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
ECS Tuning-Audi
09-30-2015 08:16 AM
ECS Tuning-Audi
09-30-2015 07:47 AM
ECS Tuning-Audi
09-30-2015 06:08 AM
