aftermarket amp 09 s5
thinking about installing some more bass in my car i want to try in install a amp by myself,because professionals try to rip your off. any DIY out there, does anybody have advise for me?
I had an amp installed last week.
ARC Audio 125 X 2 mini amp. JL Sub, Dyno Mat trunk and deck, doors. It is very loud, lots of bass. I keep the bass at 2 o'clock and it is rocking...turn it all the way up and it is way too much. I had the subwithout amp and it was pretty good.
200 for amp
65 for labor
25 for install kit
much better than doing the install myself
200 for amp
65 for labor
25 for install kit
I have installed many aftermarket amps in the past, both as a hobbyist and a "professional." That being said, I will likely bring my S5 to an insured and well respected shop and have one installed for me. If you do decide to DIY, I have read that finding a switched power supply is the most difficult part of the install. If you don't know what I am talking about, definitely get a professional install. Good luck!
Hey guys - I got this figured out about an hour ago. I fount out that in the rear there's a fusebox on the pass side, behind the little cubby box. I found the fuse for the center console aux power port. I tapped into that for the power turn-on signal to the amp. The rest of the install was cake with the battery in the trunk. I will post pics tmrw in case it helps anyone else... Kenwood 9104d amp to a single 4 ohm kenwood 12" in a 1.2 cu in sealed box. It's a perfect match for the B&O system, imo ...
had mine in for about a month now it was simple, plus i installed dynamat.
1)kenwood 9104d ,1) alpine type X 1243d 1) a spl box with 2.5ft.
anybody want pic?
anybody want pic?
S6Express
A6 (C7 Platform) Discussion
01-29-2022 04:31 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
