Audi S5 Tint Warning
So I figured that I should make this post to warn those that are planning to get their S5 or A5 tinted. Tinting is a mod pretty much everyone gets so this should be helpful.
Yesterday I took my car to a reputable tint shop and well I went to go pick it up and it turned out great
. However, as i was driving, I decided to listen to some music and no sound was coming from the the speakers at all. The MMI was working but no sound... I quickly realized that they must have shorted my amp or something with all that water they use and I was right. I went home and opened the trunk and it was pretty wet
. I called them back and said I think you messed up my speakers and they said let them dry... I was like are you serious let them dry out. You shorted something. Monday I will go to to the dealership and see if they will replace it under warranty. If not I'm going to make the shop responsible for paying for the damage.
So if you plan on getting tint make sure the shop covers up everything that can get shorted before they tint. It will save you the headache.
![Mad](https://www.audiworld.com/forums/images/smilies/mad.gif)
Well known issue, and it isn't going to be cheap to replace. Have read ~$2K. Best to use towels and plastic to cover the amp during tinting. Search A5OC forums for plenty of examples.
^^^+1. Audi isn't the responsible party over here. Even if they careless enough to let you replace it under warranty (which I highly doubt that), it's still not fair. You have to be on top of it with the shop and don't cut them any slack or else it's your own headache afterward.
Anyways the main purpose of this thread is to make sure other people don't run into this problem of assuming a business will do what it should to ensure nothing goes wrong to your car.
I just experienced this same problem as well when my windows were tinted.
Fortunately my Audi dealer replaced the amp even after asking if I recently had the windows tinted.I guess I was lucky.
In any event, I noticed on the work order that Audi also installed a shield over the new amp to protect it from future water damage. A TSB was referenced on the work order. Obviously Audi must be aware of a design defect and has taken precautions to minimize water damage problems with the addition of a metal water shield over the amp.
Sounds like an admission of guilt!
I really don't understand this happening on a car that's been out for four freaking years.
The tint shop is def on the hook for this... they should know about the B8 design and the amp/electronics being in the trunk.
Hell, I went to a small, one person tint shop in BFE and he knew about it.
