Can we see actual tire pressures in MMI and other questions
This is totally bogus. Can the VAG-COM enable this feature where we can see the actual pressures of the tires? My stoopid Infiniti had this and I know other cars do as well.
Also, is there a MMI firmware upgrade available for early 08 cars? My backup camera stays on for about 15 seconds while moving forward, the phone sometimes shrieks for a split second while dialing from the phone itself and pressing send, and finally and most importantly, my BB Storm will not stay connected to the system. Sometimes I have to delete it in the MMI and re-pair from the phone twice a day, other times twice a week.
Finally, if I make changes using the VAG-COM does it get reset at each service where the tech sets it back to factory fresh or something simple or would they have to reverse each change individually?
Thanks very much guys.
There have been several MMI updates, the dealer can do these at any time.
The VCDS settings that you change are not necessarily reset each time. I made several changes and they were not reset in a standard 5k service at the dealer. Other have had different experiences.
You can store your current tire pressure thresholds in one of the MMI menus while you're parked. So if the system relied on the rotation of the wheel to determine the pressure of your tires, how would the system know the current pressure if the wheels aren't spinning?
From what I understand, this is an incorrect statement. There are sensors installed in the wheels at the valve stem. Even VW currently uses this method for TPMS.
Here is a good article on The Indirect TPMS.
http://www.autofieldguide.com/articles/040805.html
It seems that is may not be available on all models yet. I found a post from Doc@Tire Rack that says the 2009 A6 is the only Audi using the indirect TPMS.
Actually my statement WAS correct. The current generation, including those on the A5's are INDIRECT TPMS. Therefore the do not directly measure the pressure of the tire, but take into account rotational velocity to determine if a pressure loss has occurred. What's really happening when you store the "tire pressures" is that you're storing the current rotational information. If that changes significantly, then that indicates a pressure change.
Read the article that A5_4GP posted, there is not a sensor on the wheel. It uses the ABS sensor to do the measurements. It's not inside information, it's just learning about the systems.
Additionally, here's a statement from a representative at TireRack on Audi's TPMS system, which is what A5_4GP was referring to: http://www.audizine.com/forum/showthread.php?t=188452
One possibility for not having the ability to view individual tire pressures is that Audi didn't develop the TPMS system to share the wheel sensor readings to other systems, like MMI.
Chris Brookes
11-15-2016 01:33 PM
rayden7
02-15-2012 05:24 AM
s5forum
08-06-2010 04:52 AM
Eric - The Red S4
08-14-2006 07:46 PM
Eric - The Red S4
Telematics Discussion
08-11-2006 02:28 PM
