Clutch pedal/no start issue, another perspective
Hey all, as much as I absolutely LOVE my 2012 S5, I'm exhausted, and a fair bit poorer, after trying to solve the aforementioned problem.
Here's where I'm at:
New clutch and throw-out bearing
Bled the system, no change.
Replaced the clutch master cylinder, no change.
The car drives absolutely as well as it did on day one, but I have to BURY the clutch pedal to get the starter to fire. When I hit the start button, everything I'd expect to happen, happens, but no start signal. Press the clutch as if I'm attempting to drive my foot through the firewall, and it starts just fine. When it doesn't start, I don't get the "depress clutch to start" warning, so I'm pretty sure at least that sensor/switch is working.
I have a VAGCOM: Does anyone know enough about the start interlock system to point me in the right direction so I can use the VAGCOM to read which switches are making, or not, so I can finally figure this one out?
Thanks in advance for anything you have to offer!
Skizsam
03-26-2004 06:19 PM
Pekboy
06-21-2001 11:58 AM
