Coolant Reservoir problems HELP ASAP
These past couple of months I’ve notice coolant leaking near my left axle
and also when I try to fill my reservoir the coolant doesn’t last a day in there it’s empty by the end of the day it. I sometimes smell burnt coolant as well when I drive l .I also notice that the rear thin tube tube the one closest to the oil filter is loose but it’s plugged up is it suppose to be loose Like that because it’s just hanging out
even tho it’s plugged up I feel like it should be connect somewhere someone help please
(pics are for show)
sure looks like that plastic tube is fubar'd.
Consider getting a new one to connect to the rubber line. The line is just an overboard dump (so you don't get that coolant smell when the expansion tank pukes excess coolant. FWIW, the expansion tank isn't supposed to puke coolant...if it does you've likely got other issues like a head gasket or other combustion gas leak going on. If the expansion tank is filled below the MAX line is shouldn't puke coolant. You could also have a bad expansion tank cap. The cap can be tested with the right Start tool and adapter, but it's a LOT less expensive to just replace the cap.
You might want tø test for combustion tank gases in the coolant. Here's one source:
https://www.summitracing.com/parts/l...iABEgIcIPD_BwE
combustion leak detector
I repeat...the expansion tank shouldn't puke coolant.
mikeru (09-14-2023)
It's tough to tell from the photo, but it appears the supply line from the coolant bottle (the one in your hand in the photo) is completely snapped off from the Intake Manifold Adapter. If indeed that is the issue, there is no way to "fix" the existing adapter, the part needs to be replaced. Coincidentally, I dealt with the exact same problem with my S5 only two days ago. I replaced the adapter and PCV/oil separator.
If your engine is the 4.2L CAUA (which again looks to be the case based on the photos) ... the part number for the Intake Manifold Adapter is 079133424S
Good luck!
Good luck!
(pics are for show)
LordKarnage17
10
01-10-2018 05:30 PM
I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
nvr_follow
23
02-21-2008 06:12 PM
benk
07-23-2004 06:27 AM
