E85
Eli, the window sticker for the vehicle will tell you if it's "flex fuel" rated. It probably is.
AudiWorld Expert
E85 is an abbreviation for an ethanol fuel blend of 85% denatured ethanol fuel and 15% gasoline or other hydrocarbon by volume
You can but most cars can not take high ethanol content in the fuel system and the materials used will start to corrode or disintegrate.
Google can be your friend.
AudiWorld Expert
In fact ethanol has less energy content per gallon than gasoline; hence to achieve the same power output you must burn more fuel. That's why the MPG rating for a car running E85 is much lower than if that same car runs pure gasoline. So your car burns more fuel, which costs you money.
Bottom line is avoid E85. Running E10 is OK, and in many states can't be avoided.
The 2013 2.0T in my A4 was rated for E85. The eECU auto compensated for it and the power increase was awesome. The internals were modded by Audi for strength and durability. Cons are the fuel mileage decreases by like 40% though.
AudiWorld Expert
Thanks for posting this. I never knew that the 4 banger was rated for E85. I looked it up and was wondering how I missed it
I think the 2.0T is the only engine in the USA rated for the ethanol fuel. That may have started with model year 2013.
Yeah, the EPA fuel economy ratings take a huge hit when on E85. OTOH, it used to be somewhat cheaper than Premium unleaded. Maybe not the case today??
For 2013, Audi brings to the market five models that are flex-fuel capable. The A5 quattro, A5 cabriolet quattro, the A4 quattro, the Audi allroad quattro and the Q5 are its entries.
Notably, all five models are powered by a 2.0-liter in-line four cylinder engine that is paired with an eight-speed automatic transmission offering manual shifting capabilities. Each model takes premium grade gasoline or E85 fuel. When filled with gasoline, fuel economy is as high as 20 mpg around the city and 29 mpg on the highway. When fueled with E85, these vehicles get as high as 14 mpg around town and 20 mpg on the highway.
