Fault Codes
Anyone with knowledge on seriousness and what it takes to fix these? Any information would be appreciated.
ECU info obtained with Carista 2.5 for Android:
CAN network gateway
Part #: 8T0907468F
Component: GW-BEM 4CAN-M
Coding: 000003 (hex)
Fault codes:
00473 Control Module for Electric Park- / Hand Brake (J540)
Ignition authorization
Part #: 8K0907064AG
Component: BCM2 1.1
Coding: 0D0000 (hex)
[No fault codes]
Central electronics
Part #: 8K0907063D
Component: BCM1 1.0
Coding: 26001091461CAF010000080300003D3D0F1C52880001016100 0000 (hex)
Fault codes:
Body/convenience system
Part #: 8K0907064AG
Component: BCM2 1.1
Coding: 0106029A007A448500B000 (hex)
Fault codes:
02615 Locking fuel tank cap
02616 Unlocking fuel tank cap
Driver"s door
Part #: 8K0959793
Component: TSG FA
Coding: 011C13225E002201 (hex)
Fault codes:
02115 Lock Unit for Central Locking
Front passenger"s door
Part #: 8K0959792
Component: TSG BF
Fault codes:
00920 Heated Outside Mirror (Z4/Z5)
Driver"s seat
Part #: 8T0959760B
Component: MEM-FS
Coding: 08197B25002444111000 (hex)
[No fault codes]
Front passenger"s seat
Part #: 8T0959760B
Component: MEM-BFS
Coding: 08017025002444111000 (hex)
[No fault codes]
Heater & air conditioning
Part #: 8T1820043R
Component: KLIMA 3 ZONEN
Coding: 46022000 (hex)
[No fault codes]
Steering wheel
Part #: 8K0953568F
Component: Lenks.Modul
Coding: 000036 (hex)
Fault codes:
00886 Turn signal switches (E2)
Back-up camera
Part #: 8T0907441B
Component: J772__Rearview
Coding: 1000008 (decimal)
[No fault codes]
Tire pressure monitor
Part #: 8K0907273A
Component: J502-RDK
Coding: 0CD154 (hex)
[No fault codes]
Instrument cluster
Part #: 8T0920980L
Component: KOMBIINSTR.
Coding: 8B0701000B00D705020000 (hex)
Fault codes:
Parking brake
Part #: 8K0907801C
Component: EPB Audi B8
Coding: [none]
Fault codes:
02435 Supply voltage for control module for right channel
16365 Manufacturer-specific code
00323 Vehicle Inclination Sensor (G384)
03200 Button for Electrical Parking Brake (E538)
02432 Supply voltage for left parking brake motor (V282)
02434 Supply voltage for control module for left channel
ABS
Part #: 8K0907379Q
Component: ESP8 quattro
Coding: 0F0500 (hex)
Fault codes:
Steering angle
[failed to connect]
Parking/steering assist
Part #: 8K0919475B
Component: PARKHILFE 4K
Coding: 200101 (hex)
[No fault codes]
Airbags
Part #: 8K0959655C
Component: AirbagVW-AU10
Coding: 303333333730303030304A55304C38543053 (hex)
[No fault codes]
Engine
Part #: 8T0907559H
Component: 3.2 SIMOS8.2
Coding: 01140009190F0121 (hex)
[Failed to check fault codes]
Transmission
Part #: 8K0927158
Component: 0B6 32 FSIUSA
Coding: 001002 (hex)
[No fault codes]
Headlight aiming
Part #: 8H0907357A
Component: AFS 1
Coding: 17 (decimal)
[No fault codes]
Infotainment display
Part #: 8T0035729D
Component: Interfacebox
Coding: 5003 (decimal)
[No fault codes]
Media player
Part #: 8T1035110C
Component: MP3-Changer
Coding: [none]
Fault codes:
02446 Disk drive mechanical malfunction
Media player
Part #: 4E0035785B
Component: SG ext.Player
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Component: TUNER EU/US/RDW
Coding: 2 (decimal)
[No fault codes]
Digital radio
Part #: 4E0910593K
Component: SDAR SIRIUS
Coding: 100 (decimal)
Fault codes:
02635 Tuner not enabled / activated
Navigation
Part #: 4E0910888F
Component: MNS US
Coding: [none]
[No fault codes]
Telephone
Part #: 4F0910336E
Component: Handyvorb2
Coding: 10900 (decimal)
[No fault codes]
Sound system
Part #: 8T0035223T
Component: DSP Prem
Coding: 020101 (hex)
[No fault codes]
CAN network gateway
Part #: 8T0907468F
Fault codes:
Part #: 8K0907064AG
Component: BCM2 1.1
[No fault codes]
Central electronics
Part #: 8K0907063D
Component: BCM1 1.0
Fault codes:
Part #: 8K0907064AG
Component: BCM2 1.1
Fault codes:
Driver"s door
Part #: 8K0959793
Component: TSG FA
Fault codes:
Part #: 8K0959792
Component: TSG BF
Fault codes:
Driver"s seat
Part #: 8T0959760B
Component: MEM-FS
[No fault codes]
Part #: 8T0959760B
Component: MEM-BFS
[No fault codes]
Part #: 8T1820043R
[No fault codes]
Steering wheel
Part #: 8K0953568F
Fault codes:
Back-up camera
Part #: 8T0907441B
[No fault codes]
Part #: 8K0907273A
Component: J502-RDK
[No fault codes]
Instrument cluster
Part #: 8T0920980L
Fault codes:
Parking brake
Part #: 8K0907801C
Coding: [none]
Fault codes:
ABS
Part #: 8K0907379Q
Fault codes:
Steering angle
[failed to connect]
Part #: 8K0919475B
[No fault codes]
Airbags
Part #: 8K0959655C
[No fault codes]
Engine
Part #: 8T0907559H
Transmission
Part #: 8K0927158
[No fault codes]
Headlight aiming
Part #: 8H0907357A
Component: AFS 1
[No fault codes]
Part #: 8T0035729D
[No fault codes]
Media player
Part #: 8T1035110C
Coding: [none]
Fault codes:
Media player
Part #: 4E0035785B
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Coding: 2 (decimal)
[No fault codes]
Digital radio
Part #: 4E0910593K
Fault codes:
Navigation
Part #: 4E0910888F
Component: MNS US
Coding: [none]
[No fault codes]
Telephone
Part #: 4F0910336E
[No fault codes]
Sound system
Part #: 8T0035223T
Component: DSP Prem
[No fault codes]
I got my Carista yesterday and only have one fault code, which is my horn that doesn't work. I also hav message saying to add 1 Qt oil so I bought a dipstick from ECS Tuning. My Service du needs to be reset.
Carista won't let me enable footwell lights in motion. They only come on when you open the doors.
My next stop might be to buy VAG-COM.
DanD.
A4 (B8 Platform) Discussion
10
11-25-2016 03:35 AM
ericliquid
09-17-2015 06:13 AM
