Headlight washers on S5
Is there a way to by-pass these? The manual says when you engage the windshield washers, the headlight washers will also engage sometimes. I think they come on if you're holding the windshield washers for more than 2 seconds or if you're washing your windshields for the first time over xxx days.
I'd like this to be more user defined. They tend to make a bit of a mess they way the squirt the fluid around when I only wanted a quick windshield misting.
I recall reading it from the manual, but don't have it at hand right now. Besides, I don't want them to come on everytime the lights are on and I wash my windshield if I can adjust that. I wonder if this is one of those Vag-Com modifications.
[QUOTE=tiger4366;23853501]I just gently pulled the washer lever to get a quick mist to windshield and the headlamp washers engaged, speading fluid all over the front of the car.
QUOTE]
I hate to highjack the thread a bit (but I will !)....when you spray your windshield, does it spray in 3 streams on each side, or is it more of a "fan" shape? Mine does 3 streams on each side that barely hit the windshield...
QUOTE]
[QUOTE=u080570;23853667]
Yeah, mine does the three streams too. I actually dislike the windshield washers more than the headlight washers. Because of where they are placed (I guess Audi didn't want to interrupt the flow of the hood, where I have always seen washers in the past), they end up spraying everything from the windshield back to the trunk.
QUOTE]
QUOTE]
[QUOTE=bheffern;23853683]
That's exactly what they do and makes a mess of the back window. Only way I found to solve that is to use the washers when moving at 30-35 mph. Air movement keeps the washer streams on the front window only.
Stick a pin about 1/4" in each one and re-aim to your liking. They're on ball-like swivel mounts.
QUOTE]
QUOTE]
Spoonie G
Audi A3 / S3 / RS 3 MKII
38
06-11-2015 04:21 PM
fabeneag
01-03-2005 06:14 PM
