MMI Jukebox question
If I have music loaded and want to add more, will the music that's there, stay there or will it be replaced when loading new stuff? I don't want to remove music.
It just takes so long to add songs and don't want to be waiting for everything to reload.
Thanks!
Thanks!
I was looking for an answer to my question.
Is that your first download or did you add more to the existing folder? I guess it's because I was doing the DL in the garage, it seemed so long. I should do it while going somewhere.
Thanks! That's what I wanted to know. I took the same card, added more music and loaded it. I wasn't sure if I was replacing the old copy with a new copy or it was just taking the new stuff and adding it to what's there. Now I know that I continue adding stuff on the same card.
You can buy a USB AMI interface cable that replaces the iPod cable in the glovebox if you need a USB connection (for a portable hard drive or USB memory stick for instance).
