Is premium gas really necessary?
Thinking of buying an A5 for my wife, but I'm a bit put off by Audi's recommendation of premium gas. Just wondering if I can use a lower grade of gas and, if I do, will I suffer any performance or MPG issues?
If you want to save money on cheap gas, get a Toyota.
High compression engines (especially turbo charged ones) absolutely require higher octane gas to keep from getting knock and pre-detonation issues.
Doesn't matter what manufacturer you buy from, I owned a Corvette and had long tube headers, full intake and exhaust mods and a tune from EFI Alchemy in Jacksonville. Premium fuel was a necessity. When I ran her at autocrosses or HPDE's I got the highest octane fuel I could.
My 2015 Cadillac ATS had to run premium as well, the one time I had no choice but to run regular (I lived way out in the sticks, and they had not gotten the tanker truck with premium) it ran like ****. I lost almost 7 MPG, and acceleration was crap was well. I added octane boost to try and alleviate the problem, it helped, marginally. As soon as I got down to half a tank, I filled up with Premium.
There is a reason that manufacturers recommend the fuel they do.
If you are put off by using premium, go with a car designed for a lower grade of fuel. Y
Leif
As indicated it is the high compression and forced induction (turbo, supercharged). Octane level is an indicator of a fuels ability to ignite. Higher octane has a greater resistance. If a lower octane is used predetonation can occur when the piston is too early on the upstroke causing damage to the engine. Higher compression also results in higher temps which can also cause fuel to ignite too early. You can used 91-93.
Sure, you can use any grade of gas that you want. The engine management system will take care of the possible knocking problem. You will get slightly lower MPG and performance, not linearly with the reduction in price for regular fuel. That said, I always get 93 octane (91 W of Mississippi) when I fill up. I won't be using any gas in my next car.
sheepers
10
11-03-2009 06:29 PM
cs22
10-11-2001 01:40 PM
OpusK551
9
06-29-2001 07:19 AM
