Reliability of the Naturally Aspirated V8 vs. Supercharger V6
#11
Hell, even the twin turbo in the BMW is rated lower than the NA I6 it's based on!
Spyder
#12
The torque converters in those vehicles were notorious for failing. Turbo failure as well as leaky oil seals just to name a few other "common" problems. The 2.8 was more reliable, at least in sifting through these forums when I owned an A6 and allroad. For definitive statistics, l'll have to dig up some info.
#13
In general, I would expect the V8 to be more reliable because it has fewer parts and runs cooler. Forced induction has a big twin screw supercharger than can break, more work on the belt, you have to rev it higher (has a higher redline too). In a 24 hour race the V6T would break but the V8 would be all set.
#14
My last ride was a B5-S4, which I purchased new back in 2001. The car stayed with me for close to 10 years and had ~130K miles on the dial when it left my possession. I proceeded with a stage 3 conversion when the car was ~80K by choice. At that time, the KO3's was inspected and were in perfect working order. My personal experience with this particular engine is not an isolated incident as I can easily name several previous A6/S4/Allroad owners that had shared a similar type of experience with the 2.7T engines.
With that said, I would be interested to see the stats that you can dig up regarding high failure rate of these engines, if that is indeed the case.
#15
2.7t converted from 2.8????? Where did you get that idea? Have had my B5 S4 for 12 yrs 100K miles. Except for some difficult maint - ie replacing the water pump - this engine has been rock solid. Much better than inline 6 BMW engine from previous coupe.
#16
The 2.7T was based on the 2.8 just like the 3.0 SC is based on the 3.2. Both the 2.8 and the 3.2 were modified to make the engine more durable for FI.
Bada Bing
18
12-09-2003 10:46 AM
acadia
10
03-15-2002 06:45 AM
