Review: STaSIS Rear Sway Bar
Had this installed by my indie and it took just under an hour. Initial impressions:
1. Wow that 28MM bar is beefy (and lighter than stock as it is tubular)!
2. Car absolutely feels more neutral / understeer has clearly been reduced
3. Absolutely improved levels of adhesion - there are a few corners that I had taken previously where the car would plow but now the car just simply stays planted; even at higher entry speeds
4. I no longer need to back off the throttle in order to tuck the nose in - the car simply goes where pointed
5. The car feels lighter on its feet now that it doesn't understeer so bad
6. The combination of Quattro and the bigger rear bar now allows me to power through corners / power out of corners that I previously would have been concerned about the car running wide (similar to nos. 3 and 4 above).
Overall: <b>AWESOME</b> upgrade and easily the best thing I've done to my S5 since the custom tune!!
Definitely worth the $279!<ul><li><a href="http://www.stasisengineering.com/">STaSIS - Part # for A5/S5: SA15.3100.00</a></li></ul>
Nope - had my indie do it but I did read the instructions beforehand. Pretty simple (IMHO) and as respects the exhaust, it would be easier to drop it but my indie did fine with just removing the hangers.
QuattroWerks
02-12-2009 03:59 PM
SereniTTy
11-18-2005 02:37 PM
OldSchool AG
12-11-2004 07:38 AM
sjcTT
31
02-08-2003 10:38 AM
28mm, audi, b7, bar, bars, farnbacherloles, installation, rear, s5, sa15310000, software, stasis, statis, sway, swaybar
