Rough Idle / Mis-fire at morning startup
Hello , I have a 2011 A5 2.0t awd and the issue i am having is every morning it has a rough idle or misfire at startup only when its at high idle 1800-2000 rpm then it smooths out when it drops down to normal idle it only happens when the car sits for a long time , I've changed the crankcase breather ( pcv valve ) plugs , throttle body , coils i'm thinking maybe one injector is leaking and flooding it out ,other than that the car runs great
Perhaps excessive carbon deposits on the intake valves and/or runner flaps.
Or leaking injector.
Or a head gasket failure.....when the car sits overnight, after a hot shutdown, a little bit of coolant leaks into one of the cylinders (the coolant remains under pressure until it cools down), and when you start it up the next morning, there is a spark-miss on that cylinder until the coolant is expelled. Other than slowly losing coolant, and the cold start misfire, the car ran fine after the cold-start misfire cleared.
After it sits overnight, and is cool, remove all the sparkplugs, and use a flashlight to look at each piston-top. If one appears wet/shiney, you have a bad head gasket.
AudiSportB5S4
06-24-2008 07:13 PM
slightly disgruntled
08-31-2006 08:13 AM
suffieldmedic592
10-16-2005 02:07 PM
Jon-1.8t
12-18-2003 06:29 PM
When i first turn on my car, somewhat rough idle. More idle rumble than any other time. Only 650 (m)
518 Jersey03_T
03-20-2003 04:23 AM
