Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
RS5 vs M3 & RS5 vs 911 Links inside
Old 02-09-2020, 08:47 AM
  #11
4reign_rs5's Avatar
Originally Posted by BigPoppa3
Work in Progress!!
Always work in progress lol looks awesome and
love that awe intake ❤️
Old 02-11-2020, 09:59 AM
  #12
RS5 B9
MrSpeed's Avatar
Work in Progress!!
I
i see no cats? Whats the difference without them?
Old 04-03-2020, 04:22 PM
  #13
NBRS5SB's Avatar
more power, lighter weight, better exhaust note, quicker turbo spool up
Old 08-14-2020, 06:26 AM
  #14
Wato's Avatar
Old 12-01-2020, 06:17 PM
  #15
skubeeraw's Avatar
thought it looked cool but then i see the pics and i see it looks cheap, bad light bleed, washed out uneven blacks. you van tell the diff between what audi uses and what cheap ebay hawkers are selling. ill stay away from ricing it.
Old 02-06-2021, 03:53 AM
  #16
FredAudi's Avatar
Default Question
Originally Posted by mdrobc1213
Finally arrived. Black front and rear badges. Thanks Audi of New Orleans Online sales...best price I've found online ($56 each). DITY video and links found on the forum made the front badge easier...also once you get the new one you can easily see how to release and attach it. One recommendation...take a pic of your car before your remove the prior silver/chrome badge IF you want to easily replace the black on in the proper place. I thought I remembered exactly where it went but after wiping down the front bumper prior to re-installing the new badge partially out of habit and just wanting the front to look clean as possible I had to refer to a pic of the front I'd taken to get it exactly re-established in the correct spot. Also added Richard G's front plate holders to my car....will run without a plate for now but have it mounted in the trunk...no screwed in front OEM plate! Awesome day...now for a bath tomorrow!
Black rings done! Silver RS5 badges still
Silver RS5 rear badge
Painters tape and ready for removal
Soft Pry tool set.from MACarbon
OEM Silver + Black RS5 Badges
Finished Front end - RS5 Black
Finished Rear End - RS5 Black
At the harbor - HI
how do you remove the front RS5 badge From the grille? Looks great doing mine soon 👍
Old 02-07-2021, 12:04 AM
  #17
mdrobc1213's Avatar
Order the new one and you'll see easy. Its a 2 piece design and it clips into the grille honeycomb with the rear piece securing it. Once you get it and see how it clips its easy to do. Biggest issues it to make sure you don't loose the back in the grille and have to go find it.
Old 03-23-2021, 01:47 PM
  #18
SpeedyG's Avatar
I have a 2018 RS5 Stage 3 Stertman tune, upgraded turbos, E30, catless. I have the same Trapezoid stock 20 inch with the stock Continentals. I want to go wider when I replace the tires with Michelin Pilots may 285/30 or 295/30 so I had my Tuner at EMD Auto in Anaheim CA install. 12.5 mm in front and 15mm in the back. I don't have pictures right now but it looks great and no rubbing. My instagram is misano.rs5 and I might have a pic there. I added wheel spacers after the Stage 3 Tune upgrade
Old 02-03-2022, 01:59 PM
  #19
SpeedyG's Avatar
NBRS5SB (02-03-2022)
Old 02-03-2022, 04:31 PM
  #20
NBRS5SB's Avatar
Originally Posted by SpeedyG
badass!!! Do you have a Dino 4 hp or a quarter mile time?
Quick Reply: RS5 vs M3 & RS5 vs 911 Links inside
