View Poll Results: What spacers (front/rear) for S5 titanium wheels and stock suspension?
Voters: 11. You may not vote on this poll
S5 spacers & stock suspension: any problems with 15/25mm?
I've looked at a ton of threads about spacers for my white S5 with the titanium package. The consensus is that 20/25mm front/rear is the right amount for a car that is dropped 1"+. People generally don't agree on what spacers to use with the stock suspension. From looking at pics, I feel that with the stock suspension, 20mm in the front is slightly too much and 25mm in the rear looks good.
Is it ok to run 15/25mm front/rear spacers? Does the 10mm difference have any ramifications? Does it affect handling, tire wear, or anything else?
For others finding this thread, here are some good pics:
15/20mm stock suspension (jotsy)
20/25mm stock suspension (Ben)
20/25mm stock suspension (AMDG)
20/25mm stock suspension (AMDG, angle and side shots)
One additional piece of information to save others from hunting it down: HR "DRA" spacers bolt to the hub, then the wheel bolts to the spacers. The HR "DR" spacers require you to purchase longer bolts. DRA spacers only come in 20mm+ sizes.
Found this car running 15/25, though not on stock suspension, so I would guess there isn't an issue with the 10mm difference...
http://www.a5oc.com/forums/photos-vi...sta81s-a5.html
The 20/25 setup works fine and looks good even on a lowered car. I have a StaSis suspension setup lowered about an inch with the stock 2008 S5 wheels. No rubbing even when used on the track. Don't go any bigger. If I had to do it again I think I would go 15 front and 20 rear, but it's so close
Right, 20/25mm is the biggest you want to go and most people say looks good with a drop. Without a drop, the 20mm in the front is definitely slightly too much and the 25mm in the rear is subjective: either just right or slightly too much.
Interesting to hear someone with 20/25 and a drop say they would go with 15/20 doing it again.
I think, from looking at pics, that I like the aggressiveness of 25mm in the rear. This is why I'm contemplating 15/25 with stock suspension. I know I'm totally over analyzing this, but it's what I do.
AZAudiFan
07-26-2010 07:04 AM
joseaudi
S4 (B8 Platform) Discussion
09-15-2009 08:43 AM
brody_rs4
RS4 (B7 Platform) Discussion
04-23-2008 06:17 PM
joec500
A4 (B7 Platform) Discussion
10
10-10-2006 01:16 PM
ILLZ
01-08-2004 08:12 AM
