S5 tire pressures
Per FMVSS, the B pillar label now displays MAX LOAD conditions only...5 adults weighing 150 lbs each and 5 suit cases.
Crack open your Owner's Manual and you'll find detailed info for your car including normal load conditions. The section I refer to is way at the back of the book.
Enjoy.
Welcome aboard!
Enjoy.
Enjoy.
Yep, just thought is was interesting the way it's detailed in the manual because I have always simply looked at the B pillar for my pressures on all vehicles.
I guess instead of saying interesting I should say I was using the wrong setpoints because I never run the car under the "full load" and that is where they WERE set. "WERE" because I will be lowering those pressures tonight...lowering to what setpoint I'm not sure...
From the manual (2012,pg247)
Front "B"-42psi, Normal load - 29psi, Full load - 42psi
Rear "B"-44psi, Normal load - 35psi, Full load - 44psi
