S5 VAG COM settings for voice activated telephone and remove seatbelt chime...
#81
hi,
does any one know if accessing the computer with VAG COM will also work on European MMI system?
i ordered my car with MMI 3G without Voice command and i want to know if i can activate it with VAG COM.
#83
how come when i try to change it to 10970 in my a6 c6 it says Coding Rejected, Error 31: Request out of range.
when i change it to uk english 10920 it says coding accepted but the voice still wont work.
#85
Lots of VAG COM codes and further links here:
Interesting VAG-COM codes for Audi A5
http://a6retrofit.tripod.com/articles/a5vagcodes.html
#86
In my early 2005 A8 I replaced the defuct Telematics Module under the drivers carpet with the bluetooth phone prep module; ran the fiber optic line to the digital sound system control module (in the trunk) through the wire bundle plastic tunnel in the rocker panel, and installed a new SDS speech module into the Digital Radio Module in the trunk. I had to have the dealer remove Module Protection and then it all worked perfectly. My Blackberry downoaded and can be controlled via the steering wheel voice button or on the MMI display. The entire job only took an hour.
#87
Hi:
Can anyone help with voice acti ation on my 2013 S5? I have tried to access module 5f wth my VCDS unit but keep getting a "no response from controller."
Sia Bani
NorCal Discussion
01-24-2006 03:16 PM
