Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
SD card
Old 01-06-2009, 11:19 PM
  #11
DeMOROlized's Avatar
Default Not quite.
Even if SDHC is 2GB, SD readers still can't read it because SDHC spec is simply incompatible with SD readers.
Straight from SanDisk:
The SD High Capacity (SDHCTM) card, miniSD High Capacity (miniSDHCTM) card, and microSD High Capacity (microSDHCTM) card are the new SD™ memory cards based on the SDA 2.00 specification, introduced by the SD Card Association. This new SDA 2.00 specification enables SD cards to reach higher capacities: 4GB - 32GB*.
Because SDHC, miniSDHC, and microSDHC cards are recognized by new SDHC, miniSDHC, microSDHC host devices differently than standard SD, miniSD, and microSD cards, they are not backwards compatible with legacy SD, miniSD, and microSD format host devices. Standard SD, miniSD, and microSD cards are forward compatible with new SDHC, miniSDHC, and microSDHC host devices.
Old 01-06-2009, 11:20 PM
  #12
4GB SD works fine. SDHC of any size will not work.
Old 01-07-2009, 06:38 AM
  #13
AudiWorld Expert
Boston Driver's Avatar
Default just keep in mind...
...if it is anything like the RNS-E SD card setup, it is not necessarily the size fo the card, but the NUMBER of "items" on the card (song files and folders each count as one item). I believe the limit is 512 "items"
Also, the RNS-E SD card setup has a limitation of 64 characters in a song title (the system won't simply truncate the song title, but won't display the song at all) and if there are any "special" characters in the song title, the song will not display.
I have two 2GB SD cards, each with about 35 albums on them....and it rocks!
mjg27
A4 (B7 Platform) Discussion
09-09-2009 05:00 PM
AofC_RR
08-21-2008 12:14 PM
BLULYNR - Recluse
Mid Atlantic Discussion
18
03-10-2006 12:57 PM
kujo
SoCal Discussion
05-06-2005 10:57 AM
JeremyTT
17
12-04-2002 07:46 AM
Quick Reply: SD card
