Should Battery Fail
Yes, the key to open the door lock separates from the keyfob (press button on it), also...
Yes, the key to open the door lock separates from the keyfob (press button on it), also, if the battery on your keyfob should fail and you want to start the car, you need to have the "wallet key" (black plastic key that came with your car) which you insert into the keyfob adapter in your glove box and then you can use this adapter+wallet key combo to start the car by inserting it to the keyfob hole.
The wallet key can of course also be used to open the driver's door lock.
coolxal
A4 (B9 Platform) Discussion
17
09-19-2017 01:38 AM
NiceS4
07-16-2006 09:33 AM
