Shudder at tight turns **urgent**
#11
My 2010 had a shudder in the wheel while turning at slow speeds and they replaced a steering fluid hose. It took the problem away for the most part. My 2012 does it when my car is on a slippery concrete floor. It acts real funny then. It's as if the power assist is confused. I don't worry about that. When the idle of the car is low, I think the assist isn't strong enough and makes the steering feel a bit jittery. On the previous car, just simple parking lot turns gave me that shudder which I knew was wrong.
#13
It's obvious no one in this thread knows what Quattro shudder is. All Audi's with Quattro will have a groaning shudder when making tight turns or u-turns. It comes from the all four wheels turning at different speeds, which makes the drivetrain shudder due to the mechanical gears of the Torsen having to operate at a higher rate, since they is no slippage allowed from the indifference in wheel speeds, unlike clutch type 4 wheel drive systems. The TT and A3 use a Haldex clutch for the all wheel drive system, so they won't have this shudder.
#14
#15
Depends on the exact tire, wheel size used and offset. I've had three B8 A4s, two sedans and one Avant and they all produce Quattro shudder. The shudder gets more noticeable with more miles. The stiffer tires will always produce more than a softer tire or higher profile tire. S5s always have Quattro shudder do to their bigger wheels and stiffer suspension it seems. Keep in mind, if the shudder gets really bad, it may need to be checked out by the dealer. They can at least determine if it's normal or possibly needs a Torsen to calm it down.
#16
pink shrimp
13
05-03-2008 07:49 AM
S4Dean
Rocky Mountain Discussion
03-17-2008 12:02 PM
nauticacomp
09-08-2002 09:29 AM
