Side Assist Issue
In my 09 A5, every once in a while, my Side Assist will shut off, with notification in the instrument cluster via a message saying "Audi Side Assist is temporarily unavailable". Anyone seen this and have a solution?
Considering taking it in, since I know its throwing a code via Vagcom, but thought someone might have a quick(er) fix...
I received a "Side Assist Malfunction" error a few months ago that required a couple trips to the dealer to have a module replaced. Your error doesn't seem as serious. If I recall correctly, I cleared the malfunction with the VAG-COM and it worked for a day until I received the error again indicating something was most definitely wrong.
the sensors are located (hidden) on the back bumper. just clean of the back bumper with a wet cloth, restart the car, and see if that helps. It did the trick for mine....
The sensors are actually in the two corners of the bumpers (accessible from inside the trunk, side compartments). It's not an issue with dirt/blockage, as my vehicle is always clean. It is an intermittent electrical issue (probably a loose connection), and that has been confirmed with Vag Com.
Thanks vasman, I suspect that is the problem. It's scheduled to go in Monday the 18th. I'll report on the findings when it returns.
Dealer just called. They are replacing the module and have to order it. It will be here overnight, so the car will be ready tomorrow. I'll give details tomorrow on the repair.
