Sun Roof Tinted
Had my sun roof in my S5 tinted with 5%, best $35.00 ever spent. It gets so hot on my head, not anymore. If any of you guys live in a hot area you should look into it. I am glad I did. Even here in Colorado in the summer the sun in so intense.
well, 1st, this is where the ceramic tint helps as they reflect more. 2nd, the tint is so thin that the amount of heat it hold won't do much to your glasses (imagine the different between inside and outside temp during winter days. It can get to -10 outside while inside is above 65. That alone should do more damage than the tint holding heat)
While it would seem winter should always cause a problem, cold winter air actually helps since it can cool the glass. It would be summer when the sun it most powerful that problems could arise. Think about it this way. If the inside of your tinted car ( which is rejecting a large amount of heat because of the tint ) can get to 100F, it would stand to reason the layer of glass between two heat reflectors would be significantly hotter.
I'm not claiming to be an expert on this and it all could be wrong. I'm just saying what I've read a number of times.
^^^ nice, I see the issue now. Was thinking a bit differently. Anyway, that would mean the larger the difference between factory tint and owner's sunroof tint, the higher the risk would be (unless, you want to put new tint on the outside of the sunroof, then the larger the difference, the lower risk of shattering the glass would be. Just my .02
Yes I have the Windows tinted 30% all around. Went back to have the sunrood tinted as dark as possible to make it cooler on my head. I have a close friend that does my tint and clear bra. I told him about the concerns that I read on this forum prior to having him tint it. He said he was not worried about it since the sun roof glass is tempered. It was not like he was trying to get money out of me. It was onlu $35. We will see but I am not worried .
M1LL10N
11-17-2005 07:11 AM
AudiForYou's 4.2
07-13-2003 08:39 AM
audi168
11-15-2001 09:39 PM
