For the Tiptronic guys
#11
You can have your dealer reset the ECU to original factory settings. Since the car "learns" the way you drive, it makes thousands of adjustments over time. Resetting always helps. I have mine reset whenever it's in with the dealer for regular servicings. Makes a heck of a difference.
#12
#14
I can definitely feel the downshift and upshift. I usually stick with manual mode. I just don't like how fast the auto shifts for your or late on downshifting when acceleration is needed.
#15
None that's noticable at least. My 2-1 downshift is harsh at times which we have discussed A LOT in the A4 forum. I'm travelling 300 miles for the holidays today so I'll test it out on the highway and report back.
On the upshifting side of things, I like to play a little game called 'Guess what gear I'm in'... after a stop and I get back going to a constant speed 30,40,or 50mph, I immediately try to guess what gear I am in and throw it in manual mode to see if I'm right. I'm never right. I always guess too low. Gotta love the super smooth upshifts!
until I did the vagcom to display d1-d8 too
upshifts are imperceptible, but downshifts used to change at a bit too high a speed and thus the slight bump.... now that we have about 10k it downshifts very smoothly...
have heard there is a software change to adjust the TCM - tranny ctl module...
#16
The noticeable downshifts are a "feature"... The 8-speed tiptronic actually allows the 2.0T to turn off its fuel injection completely when coasting, but in order for the engine to smoothly start up again when you hit the throttle without using the starter motor, engine speed must remain above 1000RPM-ish. So, when coasting down, the car will continually downshift to keep within that speed range.
It should be noticeable (like mild engine braking) but it shouldn't clunk or be excessively harsh, or else you might need the transmission downshift TSB that flashes the firmware. If you want to defeat that feature, you can just lightly rest your foot on the accelerator when coasting.
#19
My A5 downshifts in both D and S modes, and I always feel it. The downshifts at different times between the two, and the S mode is a bit more jerky and noticeable, but not bothersome. It's just the car's trait and I accept it.
Shamcy
12-10-2005 11:20 PM
Silver Streakin'
12-30-2004 09:55 PM
Shamcy
Audi 100 / A6 (C4 Platform)
07-14-2004 01:41 PM
MLOSU
12-23-2003 09:54 PM
Aftershock
10-17-2000 06:30 AM
