Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
V1 Install in My S5
Old 09-23-2009, 10:59 AM
  #11
tubi's Avatar
Is that rust on the frame?
Old 09-23-2009, 11:03 AM
  #12
Shado1019's Avatar
Will any of these work?
http://www.amazon.com/s/ref=nb_ss?ur...se+tap&x=0&y=0
I saw one review talking about getting the right size to fit into the fuse box for your car. Aren't all fuses in cars a standard size?
Old 09-25-2009, 04:23 AM
  #13
tcuter's Avatar
Do you have a pic of the remote disply?
Old 09-28-2009, 04:54 PM
  #14
flyfishing's Avatar
yes can you please post pic of remote display?
Old 09-29-2009, 02:37 AM
  #15
bb vign's Avatar
I didn't install the remote display although IIRC, some folks have used the ashtray.
Old 09-29-2009, 02:40 AM
  #16
bb vign's Avatar
Yes, there are two types of fuses: ATO and mini (ATO is larger). The fuses in the fuse block on the left-hand side of the dash are ATO so this one should work:
http://www.amazon.com/Littelfuse-FHA...4220714&sr=8-4
Good luck!
Old 09-29-2009, 04:43 AM
  #17
Hobbes's Avatar
It hasn't been an issue for you that the V1 interferes with your visor?
Old 09-29-2009, 06:55 AM
  #18
bb vign's Avatar
Nope - I can bring the visor down to nearly 90 degrees from the angle of the windshield which has been more than enough so far.
Old 10-01-2009, 12:30 PM
  #19
flyfishing's Avatar
Originally Posted by OC2TX
Well I followed bb vign's photos on hardwiring my Valentine 1 to S5 to a tee except for one thing. I put in the same 5 AMP fuse in slot #10 instead of the 7.5 AMP. Now I can't get power to the unit even if I use the 12V cigarette lighter and I checked it with another device to make sure it works. Did I blow a fuse in the Valentine 1 unit itself. I just got both the car and radar so I guess I have to return for repair to the V1 guys. Any thoughts.
sounds like you damaged v1. ouch...
Old 10-01-2009, 02:24 PM
  #20
Shado1019's Avatar
Good luck!
Thank you for explaining. Much appreciated.
Quick Reply: V1 Install in My S5
