Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
V1 Install in My S5
Old 03-13-2010, 05:21 PM
  #51
Hobbes's Avatar
Originally Posted by o'BlueTouring
For people who wants to ground the V1 to the bolt that's in the fuse box on driver side, you'll need a metric M8 nut. I found it out the hard way (drove my car to local hardware store and had to buy/return 3 times before I found the match. They wouldn't let me just run to my car to test it out, and they have a separate return counter which will not check out item for me).
I just used an adjustable wrench.
Old 06-20-2010, 09:46 PM
  #52
ezzonguard's Avatar
I tried to do the same with a standard adjustable ranch and fialed miserably. Any easier spots for grounding in the fuse box? i tried to screws close to the plastic panel, did not work.
Or I need a new wrench!
Old 08-06-2012, 07:42 AM
  #53
ems4ohio's Avatar
Originally Posted by bb vign
Nothing new here but for anyone looking to hardwire a radar detector in their car, it is very easy. All in, took me about 20 minutes (including searching for a switchable fuse):
1. Using a bone tool (or similar implement), run the hardwire cord from your chosen location down the front pillar, around the corner where the windshield meets the dash and back along the dash until you reach the driver's side fuse box. The bone tool does a great job of pushing the cord into the thin gap without cutting the outer sheath:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install1Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install1Medium.jpg" border="0" alt="Photobucket"></a>
2. Find a suitable location for the ground wire:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install2Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install2Medium.jpg" border="0" alt="Photobucket"></a>
3. Plug-in the cord to the connector:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install3Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install3Medium.jpg" border="0" alt="Photobucket"></a>
4. Using a TAPA Circuit (ATO, not mini), connect the lead to the end of your hard-wire connector:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install4Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install4Medium.jpg" border="0" alt="Photobucket"></a>
5. Insert a 7.5 amp fuse into the applicable slot of the TAPA circuit and tuck all the wiring in above the fuse block:
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install6Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install6Medium.jpg" border="0" alt="Photobucket"></a>
6. I used the unused slot #10 which in my car is labeled "Gearshift Gate":
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install7Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install7Medium.jpg" border="0" alt="Photobucket"></a>
7. Replace the cover and you're done!
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install8Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install8Medium.jpg" border="0" alt="Photobucket"></a>
<a href="http://smg.photobucket.com/albums/v318/lakid042/?action=view¤t=install9Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v318/lakid042/install9Medium.jpg" border="0" alt="Photobucket"></a>
Regards,
Derek<ul><li><a href="http://www.gizmos-gadgets.com/product_info.php/cPath/7_77/products_id/96?osCsid=6cacb86bd391736f1d1ac5912e118b88">TAPA Circuit Dual ATO Fuseholder</a></li></ul>
Quick note: Installed the V1 power adapter in my 2011 A5 yesterday. The driver side fuse box has 3 "banks" of fuses. The left bank of the 3 now employs mini-blade fuses (dont recall the technical name). So make sure to get the proper sized fuse tap, or use the top-most full-sized fuse in the center of the 3 columns. Its switched and works fine with the V1.
Old 09-30-2012, 04:07 PM
  #54
Magnutz25's Avatar
Fellas - I just wired my Q7 for my V1. I followed the instructions exactly, but for some reason, I am not getting power via the fuse box. I tested the cable leading to the V1 by wiring it to the lighter outlet, so the cable still works, the V1 works, the fusebox still works because the components work for each of the fuses i tried. Tried the ground in 3 different places.......
Any ideas?
THANKS!
Marc
Old 09-24-2013, 07:57 PM
  #55
seetz's Avatar
Where did you ground the V1?
Old 09-24-2013, 08:35 PM
  #56
Imola Ghost's Avatar
In the photo #6, look at the silver 10mm bolt. That's where you can ground it.
Old 06-28-2014, 10:55 AM
  #57
Digital_Bees's Avatar
Hey -- I had the exact same problem...I couldn't get power to the V1 for the life of me. I finally did tap into a fuse that worked though, after trying every single option available to me that was switched. Try using the "convenience electronics" fuse in port C location 12 in the driver's side fuse panel. For some reason this was the only place that was able to draw enough power to get the V1 up and running...
Good luck, and let me know if this helps.
Any ideas?
THANKS!
Marc
Audi #2
Q5/SQ5 MKI (8R) Discussion
9
02-22-2010 12:06 PM
BCharles
Audi A3 / S3 / RS 3
12-28-2006 12:36 PM
PILL PUSHER
Audi allroad
04-25-2004 01:54 PM
Ego
07-31-2000 05:15 PM
Brownie
04-23-2000 02:31 PM
Quick Reply: V1 Install in My S5
