Violent Shaking at Start
#22
#23
I got the car back yesterday after Step #2 ECM Flash (which I thought previously was to be a more comprehensive cleaning of the fuel system).
I did notice that on my work order receipt, the tech had noted "random misfires in cylinders #3 and #6".
I'll let you know what happens when I start it up later today.
#24
Following the ECM flash, the car still has the rough idle during startup, but I have not noticed the knocks and thumps as before. I think there was an improvement but I would have to compare it to another S5 (cold start) to really see if this was fixed.
I'm going to monitor this for a while and see if anything changes.
Anyone else with this problem find that the ECM flash helped?
#25
It started to appear on my 43k. miles 2009 A4 2.0T Quattro.
Never happened before since I've always used one gas station (shell) I'm assuming it's a gas issue since I drove from SF to LA and had to fill in LA's Chevron. So far happened twise on cold start.
#26
I just called a dealership and the service advisor said that it has been a known issue (warrantee fix) with their cars, especially the S5. She said that the engines seem to be very sensitive to the ethanol mixture in fuel and suggested I (continue) to only use high-quality 93 (I normally fill at Sunoco). She said this happens at a cold start, and the Audi engine warms up very quickly, which is why after 10 seconds or so, the idle is smooth again.
#27
I noticed a similar thing happen on tuesday while sitting in traffic. The engine was idling at 800 rpm and the car was shaking violently. I could feel it in my seat, I wasn't sure what was causing it. I assumed there may be a loose engine mount or something along those lines. after driving a few minutes it stopped. It only happened when at a stop and idling. I guess I will have to note it at my next service.
Good luck.
Good luck.
#28
I drove back from LA to SanFran and luckily this trip used 11 gallons of that ****ty chevron gas that caused shaking earlier (twise on cold start) so, after arriving to my neighborhood I used "my Shell" gas station. Next morning, cold start, no issues, smooth as it was before. So I would say stick to one brand of gas. Seems my car doesn't like gas change.
#29
Replace your spark plugs. DO NOT USE ANYTHING ELSE, BUT NGK plugs. There is a huge difference between NGK vs other vendors for Audi.
I replaced mine and the problem went away.
