***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018)
#1011
The OBDEleven doc says this about enabling the driver's seat Easy Entry memory function and action, for the passenger's side.
I am not sure exactly what actions will occur if I do these settings for the passenger side, on a 2019 S5 Prestige, B9 level.
Easy Entry
(Driver's side instructions omitted; see the doc mentioned above)Optional: To allow operations when passenger door is opened / closed:- 36 - Seat Adjustment Drivers Side
- Long Coding
- Change Easy_Entry_veh_ksv to Active
- Change Easy_Entry_veh_ee to Active
- Press and hold green check mark to accept
- Does the passenger seat have its own memory setting for the preferred position?
- That is, if a passenger sets the Pass. seat to their liking, is this remembered, just as the driver's seat preferred position is remembered?
- If it is remembered, is it specific to the key that was was used to gain entry to the car?
- If it is not remembered, then does it use the passenger seat position that was in effect when the car was turned off?
- Do both seats move to/from Easy Entry/preferred position independently?
- Or does each seat move only when it's corresponding door is opened/closed?
- Does the passenger seat move when only the passenger enters/exits the car while the engine is still running?
- Or is the Easy Entry function on the passenger side disabled when the engine is not shut off?
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x775/4a59f344_6320_4884_817c_f6d83c6d6e50_ea216247727fbb0c38404baccf4edc629a85253f.jpeg)
#1012
Started messing with my new OBDeleven yesterday on my 2019 s5....installed the “g meter” gauge, and it shows up, but never registers any movement. Anyone have this issue?
#1013
Club AutoUnion
S5 does not have the required hardware to utilize the G-Meter.
— John
— John
foreWard (02-23-2021)
#1015
Hi there guys,
I'm new to this forum and I just got my OBDeleven 2nd Generation.
I'm trying to figure out the coding for closing the trunk lid from the remote.
Has anyone been succesful ?
Thanks!
Thanks!
#1017
Made a small change last night, but it solved a slight annoyance for me. I frequently vent my sunroof and often forget to close it when I park. No problem; just use the comfort close feature. The annoyance is that when comfort closing the sunroof the sunshade starts closing at the same time. Therefore next time I get in the car I have to reopen the shade. Anyhow, if anyone else would like to do it it’s as follows:
Sunroof Module CA (can’t remember if it’s adaptations or long coding)
Power sunroof control module- convenience function
Comfort closing of sunshade- changed to “not active”
