Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018)
Old 01-24-2020, 01:07 AM
  #571
Derboy's Avatar
Originally Posted by -=Hot|Ice=-
I think I may have found out how to make Auto High Beam stick.
Try this:
Go to Unit 9
Access: 31347
Adaption
Find: "channel 5 assistance light functions-Fernlichtassistent reset"
Change to: not active
Does this work on Matrix LED equipped cars?
Old 01-24-2020, 09:50 AM
  #572
JDA_yeg's Avatar
I honestly don't think so. That coding is for the Audi TT, which is a diff platform, like the golf. This coding doesn't appear in ours, and I haven't found anything close to it
Old 01-24-2020, 02:25 PM
  #573
Club AutoUnion
PWDRSKR's Avatar
I can confirm this as I tired to do this today on my '19 RS5 using a Ross-Tech VCDS and was unsuccessful.
  • Went to 09 Cent. Elect.
  • went to Adaptation
  • Searched for "channel 5 assistance light functions-Fernlichtassistent reset"
  • There was no such option
Then I tried again by entering the access code prior to entering adaptation:
  • Selected Security Access and entered 31347 - value was rejected
Perhaps with an OBDEleven pro via an android phone it would be different but I don't have an android phone.
Old 01-25-2020, 10:57 AM
  #574
Club AutoUnion
PWDRSKR's Avatar
Got the unlock to work, but can't get lock to work at all.
I was able to get automatic unlock when approaching the ca to work (but not lock) by using my Ross-Tech VCDS. I had initially tried the the auto lock/unlock via OBDEleven app. However, it didn't work. I had to use VCDS:
46 - Central Convenience
07 - Coding
Byte 28
Bit 6 - automatic opening
set to "active"
Interestingly, byte 28, bit 7 is for automatic closing/locking. I also set this to "active". However, walking away from the car with the key in hand did not result in the car locking automatically. Approaching the car does result in the car automatically unlocking.
Old 01-26-2020, 08:11 AM
  #575
Daaavid's Avatar
So I figured out the DRL ramping for B9 A4/S4s. The coding in the current Google doc only applies to the B9 A5/S5/RS5 for ramping as I have communicated before.
Instead of "dimming_to_sl", A4/S4 owners should use "off_at_drl_or_sl". This achieves the same ramping up and down effect.
I am still unable to figure out how to keep the DRLs to remain on WITHOUT taillights (i.e. Scandinavian Taillights). This is a good compromise for me.
Old 01-27-2020, 09:07 PM
  #576
Zed 2.0's Avatar
Having trouble enabling the lap timer. In OBDeleven, I navigate to dashboard-->long coding-->binary image in the top right. The Google doc says to select Byte 1 and enable Bit 3. When I go there, it looks like it is already enabled, but I don't have any lap timer display as far as I can tell. Does this look right?
For what it's worth, I have enabled the sport HUD that displays the lap timer, and it works fine (the lap timer just reads 00:00:00).
Old 01-27-2020, 09:35 PM
  #577
heymoe's Avatar
Sounds like you have it enabled if it's showing up. Check out page 104 of the owners manual to see how to use / start it.
Old 01-28-2020, 06:07 AM
  #578
Daaavid's Avatar
Originally Posted by PWDRSKR
Has anyone tried and verified that this works? I may give it a try tomorrow assuming I can figure it out using a Ross-Tech Vag-Com VCDS interface. I've run into difficulty when trying to follow OBDEleven coding instructions on the Vag-Com VCDS on some coding changes.
This doesn't work because it doesn't exist in the scan options with my OBDEleven. I've tried to look a while back when I found a whole laundry list of items from the TT forums, but most of their options differ from our platform.
I wonder if Long Coding (bytes/bit) can be figured out from it.
Old 01-29-2020, 07:50 AM
  #579
18A5SB's Avatar
Try this:
Go to Unit 9
Access: 31347
Adaption
Anyone verified if this works on 2018 B9 platform?
Old 01-29-2020, 08:20 AM
  #580
DaveSNJ's Avatar
Probably not - I think the prior response indicates this is an MQB platform adaptation that doesn't apply to MLB B9.
Quick Reply: ***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018)
