***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018)
#741
Auto Lock - When I first got my 2018 Audi RS5, I swear the car would lock when I walked away. Whether it did or not, that is what I'd like to have happen. However, the OBD11 app for that function did not work. Anyone have any long coding data to help me? I'd really appreciate it. Thanks!
#742
#743
#744
A few weeks ago i added in the adjustment for the massage seat timer and today i added back in the heated steering wheel temperature adjustment.
Has anyone seen an adjustment to keep the fog lights on while the high beams are on? I believe this is default behavior on the european models.
#745
#746
Club AutoUnion
OBD Eleven continues to deliver the promised updates to the iOS platform for the latest hardware version!
— John
synergize (06-12-2020)
#747
For some reason your last response isn't showing in the feed - cause that would be too easy.
I have a 2018 Coupe.
Just want to make sure our wires aren't getting crossed. "D" to "S" using the gearshift, is different than "Dynamic" in exhaust settings (in Individual mode and Dynamic mode).
Again, I leave my car set to start in "I" - and even though engine and exhaust are both set to Dynamic, BOTH are ignored.
I completely understand why "I" always default the transmission to "D" (fuel economy) - it's been that way in ALL my Audi's.
However, I'm still trying to understand why, even after I shift the transmission to S, and the RPMs increase, the exhaust is still not as loud/poppy until I change out of "I" mode, into ANY other mode, and back into "Individual" or "Dynamic".
Moving between both modes (Individual and Dynamic) - after the car is already started and I've switched to "S" or it is already in "S" changes the exhaust mode to open (with pops, etc.).
It does NOT respect the exhaust setting regardless of how the car is started, and regardless if I've manually shifted to "Sport" in the Transmission, or it defaults to that (e.g., "Dynamic drive mode)".
Dealer has confirmed that it's factory behavior, but it just does NOT seem right - the reasoning from the dealer that by not opening the valves, the cats would warm up more quickly.
But then that should mean they would open after a period of time - which they do not..
They NEVER fully open unless I cycle the car, after start, into "Individual" or "Dynamic" modes.
Every loaner car I've gotten, A3's, Q3's A6's, etc., have respected ALL settings in the "I" mode, including exhaust, but you must always manually put the transmission into "Sport" mode.
Among other things:
The B9's (2018 at least) will not save your last known recirculate setting without a mod, it will not respect your HBA setting upon re-start (no one can find a mod for this), and several OTHER settings are not retained after re-start.
With most of us waiting a year for them to release a software update to fix the 3d camera view sticky issue post re-start, some of these other "features" seem like they were also forgotten as fixes between software updates (ECU, 5F, etc.) and we are left to manually reset them - like a pilot's pre-flight check list, I have to literally press like 5 different buttons to get the car the way I want to drive it before I drive off.... every time.
So why does the B9 platform, or at least the 2018's and earlier, not respect drive mode settings and other settings upon re-start?
Does the exhaust setting in "Individual" mode get saved and respected upon re-start in "Individual" mode?
I would ask that you try this:
Start the Car in Comfort mode.
Switch the transmission to "Sport".
Then cycle the car to "Dynamic" drive mode - and listen to your exhaust note.
Among other things:
Do other drive select options (e.g. sport differential) also require a cycling of the drive select modes? The exhaust note is easy to notice as it is aural. The other settings not so much...
#749
Any luck ever solving this issue with the car remembering the exhaust setting upon restart?
I solved it with a CETE module as the dealer offered no assistance.
What they seem to forget is that after 10's of 1000's of complaints worldwide about the 360d camera not retaining it's settings, it took them almost 2 years to issue a fix.
I believe this will be the same here.
There are OTHER settings that also don't save (like HBA) that just make me scratch my head.
#750
There are a few references in the Sunroof and other modules that indicate there is a way to get the sunroof to open above a certain temperature....
Anybody have any thoughts on this?
