***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018)
#901
The instructions reference a MMI setting which allows storage to the key fob. Can you confirm that this option/setting does not exist in the 2020 MMI?
Thanks again---
#902
I don't believe that it does. Next time I'm connected I'll take a screenshot of my "history" page to see exactly what I did.
#903
Hopefully it will stick.
Thanks again for your help.
#904
The below applies to a 2020 S5 SB Prestige:When I went in with my OBD11 and called up the F5 module/locked functions I looked at FB_NAV_3.
The document posted on this thread shows the default to be blocked, with instructions to change to non_blocked.
However, in my case, it was already non-blocked.
So, just for fun, I changed FB_NAV_4 from blocked to un-blocked.
In a short, low speed test drive, panning and zooming was allowed.
I am wondering if the 2020 MMI has some different option locations.
Having been used to the 'old' MMI (wiz wheel) I found the inability to pan/zoom to make the GPS almost useless when under way.
Locked menu contents →
FB_NAV_3
blocked
non_blocked
FB_NAV_3
blocked
non_blocked
#905
sorry..didn't get back to you, but yes I tried with hood up, doors open/close, etc.
Finally got it working but that one bit in module 36 refuses to change to 1.... maybe it needs therapy... it refuses to be anything but a zero!
MRA5SB (09-18-2020)
#906
FB_NAV_3
blocked
non_blocked
FB_NAV_3
blocked
non_blocked
#907
FB_NAV_3
blocked
non_blocked
FB_NAV_3
blocked
non_blocked
#908
Do I need to code that middle light on (red arrow) with OBD11 or is that a fake light?
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/256x554/img_5541_b2a1bdb4a844f1cdb7e6e630fa150241fd95dece.jpg)
#909
So exactly what did you do different to get the easy in/out working? Might be useful to others to know. Perhaps even edit the Coding Thread doc with the exact steps.
#910
Hot|Ice: On my 2019 S5 Prestige I cannot get the Low and High beams to both be on at the same time? When you look at the driver side headlight (from L to R) from the front the First light in the housing is the All Weather Light, the second light is a reflector (it has a yellow object inside), the Third light is a projector light with a convex lens. How do you turn on the middle reflector bulb, there is nothing in the manual about that middle light? Thank you for any info?
Photo below is standard low beam:
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/700x467/kzgh54v_40f287925c9b53ce7476cde79e8d58d8887a20f8.png)
Photo below is high beam + low beam. To achieve this, you need to code it, but it will only occur during when you flash the high beams or when you force the high beams to be on. It is not always on with the headlights.
![](https://cimg1.ibsrv.net/gimg/www.audiworld.com-vbulletin/1920x1080/codczlk_19797e519f9bd139222319df189eb037e1294a6e.png)
The following 2 users liked this post by Daaavid:
-=Hot|Ice=- (09-20-2020),
synergize (09-19-2020)
