2018 S5 Occasionally Won't Start, Sputters and Dies
Club AutoUnion
Hello all. I've had my 2018 S5 coupe for almost a year now. I've driven over 12000 miles (currently at 43000 total) and it ran beautifully up until the last 2 weeks. I took it to the Audi dealership for an oil change, but they told me it was time for the 40K service so I let them take care of all of that (Fluids, spark plugs and a few other items basic checks.)
Two days after the service, I started the car and it ran really rough before turning off after about 10 seconds. It flashed a message on the dash saying "Engine RPM reduced to 3500" and threw a check engine light. It did this twice before I left it alone. I tried a third time and it didn't start at all. As I was about to arrange a tow truck, I decided to try it again about 10 minutes later and the car fired up and worked as through nothing had ever happened. No rough idle, and started very quickly.
I was able to get an appointment at Audi the next morning and took the car in for them to take a look and at least determine what caused the check engine light. At this point the car was still running perfectly. They told me the code was a "sporadic error" but they couldn't find anything. They cleared the code and gave it back. The car ran perfectly fine for about 2 weeks before doing the exact same thing again yesterday. I started the car, it ran really rough for a few seconds and cut off. This time I waited an hour before trying again. Once again it fired right up as though nothing happened. I had an old OBDII bluetooth reader and was able to determine that this time the car threw a fault code of "P2635 - Fuel Pump A Low Flow / Performance". (Not sure if it was the same code last time.)
The error suggests a fuel pump issue, but I'd expect to also see some issues while driving. So far this is an intermittent issue that happens only at startup. I'm just wondering if anyone else has seen anything similar or know of a potential cause of this behavior? It could be a coincidence that this all started after the last service, but I never had a single hiccup with the car before this so I do wonder if something they did triggered this.
I'll add an update on what Audi says, and anything new I find.
I had a similar issue in my 2018 RS, although engine speed was never reduced. Also I could hear the fan noise didn't sound right. In my case the initial problem was with the thermostat and the SA said rough starts could absolutely be related.
They couldn't find a fuel issue and cleared the fuel pump code but it returned a month later. Right now the car is in the shop and it looks like they have ordered parts for the fuel system. Still waiting on them to arrive and then get my update.
I'm lucky that mine is still under the CPO warranty and techs saw both errors. I'll try to keep you informed if they solve the fuel pump error.
Club AutoUnion
Good luck and Welcome to AudiWorld.
— John
bdh1119 (07-11-2022)
There is a fuel pump issue that Audi has acknowledged — but IIRC, it was for the A5 series, not the S5 / RS5. If you search this sub-forum (which is a PITA) you’ll find a thread or two with the information. I also wonder if it could be a clogged fuel filter somewhere in the fuel line system?
— John
— John
Is this what your are referring to, an Extended Fuel Pump Warranty for 15years or 150k miles, not sure if it is for all B9s or just the 2019. I got this about 1.5 months ago. Did you get it? If I'm not mistaken, I believe this extended warranty is for all B9 cars?
![](https://cimg4.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/img_1738_4eceedbc07a0e8481749543805abc26118edd5f9.jpg)
Nikon1 (07-11-2022)
Club AutoUnion
synergize (07-11-2022)
find the fuel pump relay and get the dealer to replace it. On BMW E46 it's (salmon relay) notorious for SMG power problems.
It's also possible the fuel filter or fuel pressure regulator is acting up, at 40K it probably should have been replaced but I guess Audi doesn't specify it. I went through a fuel pump, fuel filter/regulator around 60K on a port injected M3 motor...your direct injection is likely more sensitive to fuel. Additionally, consider scoping the intake ports...DI can often end up with carbon deposits all over the intake valves/ports. Deposits can cause hard starting and rough idle/running.
Club AutoUnion
— John
— John
Club AutoUnion
This thread has already reminded me why I appreciate forums so much!
My current theory is that either the relay or the electric fuel pump is having an issue. Whenever the car is running, it never has any issues or hesitation while accelerating. I'm thinking that an intermittent issue with the electric pump or relay prevents fuel from reaching the engine so it can start and allow the mechanical engine driven pump to take over. Since the engine driven pump takes over, that would explain why I haven't had any issues while driving.
I'm guessing that the initial rough engine start happens because of fuel already in the system, but once that runs out the car turns off. This is my current working theory. I'm taking the car in tomorrow and will see what they say although its possible that they may not be able to see it due to being backed up. I got a call today that they may have to keep my car for up to a week depending on workload so we'll see how that goes. Either way I'll post an update here.
a fuel injector(s) leaking would also fly...no pressure in the fuel line until the fuel pump(s) bring it up. DI problems....
Stephen_S5 (07-12-2022)
Hopefully Audi has or will solve your issue as well.
