2018 S5 SB Prestige sunroof compared to 2017 A4 Prestige sunroof
The 2017 A4 Prestige describes the sunroof as:
"Sunroof with sunshade, power tilt and slide features"
The 2018 S5 SB Prestige sunroof is described as:
"Panoramic sunroof"
I have some questions:
Does the Panoramic Sunroof have the sunshade, power tilt, and slide features?
Are they the same sunroof?
If they are not the same, what are the differences?
Thanks All!
"Panoramic sunroof"
Thanks All!
The panoramic sunroof will tilt and slide similar to a normal sunroof but it has a thin fabric shade that rolls up and blocks only some sunlight while the normal sunroof has a thicker, sturdy shade that slides back and forth and blocks all sunlight.
"Panoramic sunroof"
Thanks All!
"Panoramic sunroof"
Thanks All!
And that shade is power operated separate from the glass portion of the roof.
Yep, A4 has a manually moveable panel that slides back and forth - some small vents in the front part of it. Can be closed if roof is opened or closed.
The A5 has the larger panoramic, and the sunshade is powered (button is right behind roof button on roof console). It also can be closed when the roof is opened, but is a breathable fabric - sort of a dense mesh.
No problem.
By the way, there are a couple other good videos on the car in this thread:
https://www.audiworld.com/forums/aud...video-2921215/
hevnsnt
16
03-18-2022 03:43 PM
e46fanaticsFTW!
09-26-2001 05:25 AM
