2018 S5 SB Prestige - VCDS - Dealership disabled ACC, ALA, Pre Sense
Backstory - I put an aftermarket bumper on my 2018 S5 SB Prestige. Due to the new bumper, my sensors on the front were lowered and out of alignment and I had the dealership disable some things to avoid getting notifications in the Audi. I have since put the original bumper back on with all the sensors in place. I ordered VCDS from Ross-tech and did a scan with the intent of turning the Adaptive Cruise Control, Active Lane Asist, back on using VCDS. The scan returned a number of malfunctions (removed modules that did not show any malfunctions from the list below). I would have expected to see some malfunctions, but not as many seemingly unrelated modules, but the electronics in these cars rely on other electronics so it does make sense. Given that and the specific faults listed below, could someone please provide some insights in where to start looking or things to check in VCDS to turn on or off to get everything working again? I can send the adaptations if needed as well (PM me).
UPDATE: I had to replace the right front ACC sensor. I hit a small animal and it destroyed original sensor.
Thank you!
List of Malfunctions
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Cannot be reached 0100 <- I can get into this one, but it's intermittent
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
82-Head Up Display -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100 <- unable to get into at all
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Wednesday,11,May,2022,19:16:31:06921
Chassis Type: F5-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
6C 6D 81 82 8B A5 A9 BB BC CA CF D6 D7
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 H HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0008
Revision: B2H22000 CVN: 30D654D0
Coding: 1A2A00322366010E34280000000000000000000000000000
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559H 001009
ROD: EV_ECM30TFS0118W0907559H.rod
VCID: 4ACD6C1E8C3EB9CB51B-801E
VINID: 9D195311458501A4402401C8189E4FC0CA
2 Faults Found:
28212 - Exhaust Pressure Control Valve 2
P049F 00 [047] - Malfunction
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:37
Engine RPM: 599.50 /min
Normed load value: 7.1 %
Vehicle speed: 0 km/h
Coolant temperature: 102 °C
Intake air temperature: 66 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 12.780 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
Engine RPM: 576.50 /min
Normed load value: 8.2 %
Voltage terminal 30: 12.880 V
Com st X Set2 Val1-Bits 0-7: 0
Com st X Set2 Val2-Bits 0-7: 0
Com st X Set2 Val3-Bits 0-7: 216
Com st X Set2 Val3-Bits 0-7: 0
Com st X Set2 Val4-Bits 0-7: 0
Com st X Set2 Val5-Bits 0-7: 0
Com st X Set2 Val6-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 1
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 M HW: 8W0 907 379 D
Component: ESP9 Premium H13 0767
CVN: 6C105E67
Coding: 1CAA149A30AB0A9611A54899008352A2E4259A38280C508812 004A4527A459
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 4FFB7D0A775C9CE3065-801A
3 Faults Found:
337664 - Databus
U1121 00 [047] - Missing Message
[ComScl:_Signal_Group_SG_ACC_07_-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
00 00 80 00 CA 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
271360 - Databus
[ComScl:_Signal_Group_SG_ACC_10-_Timeout_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
364032 - Voltage Support Terminal 30 for Electronics
U141C 00 [047] - Open Circuit
[UB_ECU_supply_line_interruption_(defect_fuse:_brok en_car_wire_harness_or_very_deep_undervoltage)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:36
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 1608050D5544010D1002010088000000000000000000000000 0000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14226AE1A6FBBAB7-8010
Fresh air blower control module (front):
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002185616
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 4C92951900PAG0MUFU02
Rear A/C control head:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
No fault code found.
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E0691CCD050D511918AC9CB9110B3D040000000000 00000020001A010A69012B025709
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 025D843EF48EA18BD9B-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 030218 036 0471
Serial number: 00000001801290303296
Coding: 5FC7F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21178111X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AL HW: 4M0 941 531 AL
Component: E1 - LDS H06 0008
Serial number: 12 12 2017 01213302
Garage door opener control module:
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00YN02
Coding: 350000
Garage door opener control head:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180213103617 00409
Automatic dimming interior mirror:
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE109011823611599
Coding: 010000
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00703499
Control head for driving and comfort functions:
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000308685007
Coding: 000000
Valve block 1 in front seat driver side:
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0034
Serial number: 7008174235B180101408
Coding: BF0500
Valve block 1 in front seat passenger side:
Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0034
Serial number: 7008174235B180513279
Coding: B30500
1 Fault Found:
8W0 907 063 BG
[Distance regulation control module: no signal/communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:46
average_Voltage_terminals: 12.00 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 37.50 °C
interior_temperature: 32.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0107
Serial number: 003UQ002FLCN
Coding: BFFCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4DC767027D50AEF3749-8018
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2040
Serial number: 8W0857705M0249T00761
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0059S00134
Coding: 80000D
Seat occupied recognition passenger side:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180008YFSU0H
Crash sensor for side airbag: driver side:
Subsystem 4 - Part No SW: ----------- HW: 442 061 802 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00A528D6162320S
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 5 - Part No SW: ----------- HW: 442 061 802 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A528D6162456$
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 802 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C52987FE2C0CZ
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 7 - Part No SW: ----------- HW: 442 0B0 802 18
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700C52987FE2824Q
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 701 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B32982D1150E8
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 701 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B32982D13B0FI
Coding: 2D2D2D
5 Faults Found:
1054464 - Databus
U1121 00 [009] - Missing Message
[NWD: 0x117 ACC_10 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1065984 - Databus
[NWD: 0x360 SDF1_SensorHeader Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1060608 - Databus
[NWD: 0xTBD SDF_PSF_01 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1064192 - Databus
[NWD: 0x2A9 ACC_15 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:48
1063936 - Databus
[NWD: 0xTBD SDF_PSF_Obj_01 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
Component: FBenUSA H18 0373
Coding: 09EF49CB6C8CCF0502A3ED601808400008000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
2 Faults Found:
16777042 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[BAP_ACC_0x05 communication error bap_error_timeout heartbeat]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:37:18
16777089 - Databus
[ACC_12 communication error can_error_timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:09:52
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W8 907 468 F HW: 8W8 907 468 E
Component: Gateway H42 0123
Revision: 7D000001 Serial number: 0187D530818225
Coding: 03010003000006405407000000590012FC1800071000000001 75078E10000000
Shop #: WSC 36059 003 104857
GVL: 01503C180800000040DCC8000002C800100C00000000000000 00000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180228135337 21272
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 6891987004
2 Faults Found:
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout_Node_0x57_DiagAdress_13_ACC]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:43:02
131670 - Automatic distance regulation 2
U1071 00 [009] - No communication
[Timeout_Node_0x56_DiagAdress_8B_ACC2]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:43:02
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 J HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0411
Coding: 0D008380008080
Shop #: WSC 18450 005 1048576
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
2 Faults Found:
35072 - Databus
[KFC_ACC_07_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Expanded ambient data 1-Engine running: Engine_not_running
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 4
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 137
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 6 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.20 Nm
Expanded ambient data 1-Steering_Torque_Sign: 0
Expanded ambient data 15-MsgStateFifo_Byte0: AA AA AA AA
Expanded ambient data 15-MsgStateFifo_Byte1: AA AA AA AA
Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
Expanded ambient data 15-NumOfMsgCntFaults: 00
Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
Expanded ambient data 15-NumOfMsgNoFaults_3: 00
Expanded ambient data 15-NumOfMsgTimoFaults_1: 19
35840 - Databus
[KFC_ACC_10_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Expanded ambient data 1-KFC: 140
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 B HW: 8W5 035 880
Component: MU-P-LNS-US 034 1178
Serial number: A798B0JB087355
Coding: 019453020000000053220002041A00102F0012E501700904BE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 3E2530CEC0F6056BFD3-806A
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 DM HW: -----------
Component: NAR 2019/2020 --- 0072
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00103121700820906
Multimedia system control head:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK125091700020327
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3012
1 Fault Found:
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:55:40
Voltage terminal 30: 12.9 V
BAP-BAP_Function_ID: 02
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 8W6 919 617 HW: 8W6 919 617
Component: HeadUpDisplay H09 1640
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 0655982ED8A69DABF53-8052
1 Fault Found:
16777010 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Address 8B: Adaptive Cruise 2
Cannot be reached
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H16 0050
Coding: 0404090300000203022023A6AD0000FCB0F0C020C020
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 40D94E36BA02739B8FF-8014
3 Faults Found:
1122561 - Databus
[TIMEOUT_ACC_10]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Control Module temperature: 48 °C
Voltage terminal 15: 12.10 V
1123735 - Databus
U1123 00 [009] - Received Error Message
[APS_Master_US_relevanter_Fehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
4195336 - Databus
[STA_communikation_failure]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0EC002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 333311FAFBB4D80302D-8066
End----------(Elapsed Time: 02:20, VBatt start/end: 12.9V/12.9V)-----------
Thank you!
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:37
U0235 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
CVN: 6C105E67
3 Faults Found:
337664 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
271360 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:35
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 172065 km
Date: 2022.05.11
Time: 18:24:36
Coding: 5FC7F7
Coding: 02005D
Light switch:
Coding: 350000
Coding: 010000
Coding: 000000
Coding: BF0500
Coding: B30500
1 Fault Found:
8W0 907 063 BG
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:46
Cannot be reached
Coding: 80000D
Coding: 80000D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
5 Faults Found:
1054464 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1065984 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1060608 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
1064192 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:48
1063936 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
2 Faults Found:
U0235 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:37:18
16777089 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:09:52
2 Faults Found:
U0235 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:43:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:43:02
2 Faults Found:
35072 - Databus
[KFC_ACC_07_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
35840 - Databus
[KFC_ACC_10_TIMO]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Data carrier:
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 18:55:40
Coding: 4F01E0
1 Fault Found:
16777010 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Cannot be reached
3 Faults Found:
1122561 - Databus
[TIMEOUT_ACC_10]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
1123735 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:47
4195336 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 172065 km
Date: 2022.05.11
Time: 17:52:44
Revision: --------
Coding: 0EC002
Update
when I try to go into the 8B Adaptive Cruise 2, Open Controller, comm status says: CAN init Failed. Also a VCDS Init Contoller warning box pops up and shows: No Response From Controller.
JASON BYEON
VAG-COM Discussion
03-27-2024 10:56 PM
zore
Q7 MK 1 Discussion
11-01-2020 08:13 AM
