Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
2018 S5 Sportback Lowered on 20s
Old 04-28-2018, 08:11 AM
  #141
McGriddle's Avatar
Great work... the attention to detail shows! The RS grill looks perfect.
Old 08-22-2018, 03:16 AM
  #142
Shreyas Zanpure's Avatar
Originally Posted by BreedsAs
Thank you!
I did the majority of the install myself. The only part I did not do was the actual fabrication of the enclosure. That was made off my input, while a local custom car shop did the actual work on it. I did the amp and wiring install. I also supplied all parts
All in all, I paid $1,350 total.
Assuming you had someone do this work for you, expect to pay between $1750 - $2250 depending on location and equipment brand quality.
Anything more than that is an absolute rip off.
Hi Breed, you car looks stunning! I just had a quick question regarding lowering springs. The link you posted at the start of the thread points to A4/AllRoad version, whereas there is also a B9 S4 version out now
https://store.034motorsport.com/dyna...9-audi-s4.html
Did you fit this one on your car or the A4/All Road version?
https://store.034motorsport.com/dyna...4-allroad.html
I am wondering if the B9 S4 version will fit my S5 Sportback with 19" Cavo design wheels. TIA
Old 08-22-2018, 12:30 PM
  #143
BreedsAs's Avatar
Thank you Shreyas.
When I purchased my springs, the S4 springs were not available. Only the S4 were. I can guarantee you that the A4/A5 and S4/S5 have just about identical suspension components so the part are intercahngeable.
That said, the 034 A4 and S4 offerings look the same (physically). There is a minor difference in spring rates though for the front springs. The new S4 offerings have a higher rate than the A4 springs. Either will fit your B9 S5 with Cavos, but I suggest you get the S4 springs since they now offer it.
Old 11-23-2019, 08:44 AM
  #144
Bart de Rede's Avatar
how much is it lowered? greetings
Old 11-24-2019, 02:15 PM
  #145
BreedsAs's Avatar
1 inch all around
Old 08-29-2020, 12:46 PM
  #146
LLeon24's Avatar
Originally Posted by Quattrings
Your car looking perfect as usual. The brushed window trim really meshes well with your wheels too.
So the parts for our fix came in. Trying it out now. So far sizing and connector are right on. Will report back if it works.
Hey all! I just installed the RS5 grille on my B9 2019 A5 and having the same problem with the sensors. Are these different sensors you purchased? If so, where can i get them if they fit!
Old 08-29-2020, 03:29 PM
  #147
Andy_FL's Avatar
The "right-angle" sensor: 5Q0 919 275 B GRU
You can find them on your own car already - at least, they were present on my S5 as the "outer" two front bumper sensors. GL.
Old 08-30-2020, 03:28 AM
  #148
LLeon24's Avatar
Thanks a mil! -LNL
Old 12-28-2023, 06:40 AM
  #149
Flyfaster1's Avatar
Bringing this old thread back b/c your wheel setup is on point. Would a +35 instead of a +33 work and tuck the wheels in a touch, without rubbing on a 275/30/20 or a 285/30/20?
Old 12-29-2023, 01:57 AM
  #150
BreedsAs's Avatar
Hey there,
There is no way you'll clear 285s while lowered. It'll rip the fenders out.
Quick Reply: 2018 S5 Sportback Lowered on 20s
