When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Well, I'll be checking my map version in a bit and applying the update if necessary. Just need to find an SD card.
This is the required file structure to get the map software updated, looking at the cards Root Directory: (dates in file info are related to the date I unpacked and created the files — your Jan 2021 dates will be different):
Just downloaded it and will do it next time I start up the S5. Currently hibernating in the garage under a cover...
Is there an expiration date when I can no longer update this set of maps to the car?
2.5 years After the actual “Build Date” (see the label along the bottom rear edge of the drivers door for month and year of your cars build date).
I used the file DCB1951 posted. Worked perfectly. It did not include the WMPinfo document file listed in Nikon1 screen shot. Anyone know what that file/document is?
