Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
2019/2020 Map Update Is Available
Old 01-07-2021, 05:41 PM
  #511
Permanent S Mode Member
MH62's Avatar
Originally Posted by NJS5
I used the file DCB1951 posted. Worked perfectly. It did not include the WMPinfo document file listed in Nikon1 screen shot. Anyone know what that file/document is?
That's extra Windows baggage generated when files are manipulated on USB drives. I think it comes from Windows Media Player saving info about music files on USB drives. It's not related to the maps package at all.
Nikon1 (01-08-2021)
Old 01-07-2021, 06:51 PM
  #512
NJS5's Avatar
Thanks MH62
Old 01-08-2021, 06:22 AM
  #513
sthulin's Avatar
I used the file provided by MH62 (and adjusted the extraction to make the root folder correct) and the update applied successfully.
Old 01-08-2021, 11:26 AM
  #514
Tesla1856's Avatar
Thanks for the report.
I went ahead and got both, but I figured that would work just as well.
Old 01-08-2021, 12:55 PM
  #515
18A5SB's Avatar
Does this update include maps for all US States? The 1613 that I had downloaded and installed did. So far any glitches seen by anyone?
Old 01-08-2021, 01:09 PM
  #516
synergize's Avatar
Received 1,254 Likes on 774 Posts
Question for the forum: If using a Mac (Big Sur 11.1) and doing the map update via Thumb Drive would you format it in Fat 32?. Thanks.
Old 01-08-2021, 01:31 PM
  #517
JohnEnglish's Avatar
Yes and make sure the drive isn’t bigger than 32 GB.
synergize (01-08-2021)
Old 01-08-2021, 02:10 PM
  #518
BrainDr's Avatar
Originally Posted by DCB1951
Here's my link, as promised: https://1drv.ms/u/s!At652cvGKNNQgb4ioFxxYEFcnMh5qQ. Let me know if you have any problems.
Worked perfectly for me - thank you!
DCB1951 (01-09-2021)
Old 01-09-2021, 02:00 AM
  #519
wrecklesswun's Avatar
Originally Posted by Nikon1
I just checked the Audi web site and the Complete 2020 Map Update is available for downloading via the computer. As this is a 10.4 GB file download for the complete package, I download it to my computer then copy it over to the MMI via an SD Card.
For the new members - Someone created the instructions below for downloading from the Audi site to your computer, so all thanks go to that unnamed member. Audi's Rules for the New Members are at the end of this posting.
Downloading Map Updates:1) Get a 32 Gig SD memory card. Mine cost $20.
2) Go to My Audi site, https://www.audiusa.com/myaudi. Log in.
3) Click on the “Audi connect services” icon (below the car).
4) On the services tab, click the right arrow to scroll to “Map update.” Click on it.
5) You can choose “Complete package” or “Individual country.” Your choice. I chose complete package.
6) Put you SD card in your computer. Alternately, you can load the map files to your hard drive. Click on “prepare package” at the bottom.
7) This will download a file called “downloader” with a bunch of numbers after the word.
8) You MUST have the latest version of Java. It will prompt you if needed.
9) On the Mac, I needed to go into my security settings to allow the downloader file to open.
10) It will open with a Java screen, followed by a Download client window that says “my Audi.” It asks you to choose a folder location for the files. Pick a location on your hard drive or SD card and click to go.
11) The download starts and is tracked in the Download client window. The size of the files is 10.6 gig. It took about 2 hours to download on my computer.
12) Once the files are downloaded, transfer them to your SD card if you didn’t load them direct. There will be two files “0231001C.md5”, “metainfo2.txt” and two folders “Mib1” and Mib2”. All are needed.
13) Go to your car. You can do this while you are driving or stationary but the car must be on (not necessarily running but on).
14) Stick the SD card into the SD1 slot in your glove box.
15) In your MMI, go to Main menu>>Settings. Push the MMI scroll wheel to the left, it brings up a menu that says “MMI setup” and “System update.” Pick “System update.”
16) Pick SD1 (i.e. where you put your SD card) and press the MMI button to select.
17) The nav update will start and inform you of progress on the MMI screen. updates took about 20 minutes to load.
Audi's Update Rules Are:
1.The latest map updates can be downloaded here free of charge and then installed in the vehicle via SD card. You can download and install the updates an unlimited number of times. The Map Update includes the first five updates to the version of the map installed at the factory. The updates are issued every six months.
2. Transferring the new map package overwrites the map package currently stored in the MMI. The currently installed version can be found in the MMI under -> Setup MMI -> Version information -> Navigation database country versions.
3. You can also have the new map data installed by an Audi dealer (there would be a charge for this service).
Happy Updating!
--John
I was able to do this on the S4. Since upgrading to the RS5, this no longer works...
Old 01-09-2021, 03:43 AM
  #520
Club AutoUnion
Nikon1's Avatar
Received 2,213 Likes on 1,408 Posts
Click on this Map Policy Link And read as much as you can.
TLDR: Audi has changed the method of map updates. The process described in first post has been changed and, for now, all updates are performed OTA within your car. For now, the map updates offered are just in the immediate area where you reside.
This information is subject to change, based on AoA policies.
— John
Quick Reply: 2019/2020 Map Update Is Available
