2019 A5 Homelink wont work with Genie smart garage door
Tried setting up the homelink with my Genie Quietlift connect 750 but it dint work. I go this instruction set:
Step 1. Begin by clearing the Homelink by pressing and holding the two outer buttons until the Homelink indicator light starts to blink, which may take up to 20 seconds.
Step 2. Press and hold desired Homelink button until indicator light flashes slowly. Once+indicator light is flashing slowly, release the button. The vehicle is now in training mode. You will have 5 minutes to train your remote to the Homelink transmitter in the bumper.
Step 3. Stand in front of your vehicle with the genie or overhead door remote that you will use to train the vehicle. The Homelink transmitter is in the front bumper about 4 inches to the left of the vehicles center.
Step 4. Hold the remote between 0-12 inches from the vehicles bumper. a. Note: The distance between the remote and the Homelink transmitter unit in the bumper depends on the system being trained. It may require several attempts at different distances in order to pick up the signal.
Step 5. Now press and hold the button on your remote while keeping the vehicles fog lights in view. The fog lights will blink three times to indicate the training is successful. a. If training has exceeded the five-minute timer, the fog lights will blink 1 time. If this occurs, repeat steps 2-5.
Step 6. If the unit is fixed code, training should be complete and the trained Homelink button should light solid and operate the door. If the unit is rolling code, the trained Homelink button will blink rapidly and then turn solid, indicating you should proceed to step 7.
Step 7. At the powerhead, locate the Learn Code or Program Set button. Place the unit in programming mode, you now have 30 seconds to initiate the next step.
Step 8. Return to the vehicle and firmly press and hold the trained Homelink button for two seconds and then release.
Repeat this 3-5 times, or until the door runs.
Did anyone here have
This is the door opener model
problems, did they use the instructions above, please help. Been stuck using the handheld transmitter instead of my car's own door opener button for a year now.
where did you find these instructions? I did mine from inside the car following the instructions in my owners manual.
Update: Finally got it to work (for anyone interested) should work on all 2018-2019 models with homelink.
Step 1: Clear programming in car's homelink menu
Step 2: Press the button you want to program, until MMI shows the option to begin programming said button (I in my case)
Step 3: Follow instructions on screen till you get to the point where it asks 'Is your garage door moving'
Step 4: If your garage door dint move due to rolling codes, go back to your door opener unit.
Step 5: Press the PROGRAM button on the bottom of the door opener, next to the the +/- buttons until blue light starts glowing, at which point release the button
Step 6: As soon as the purple LED (oblong shaped) on the opener started flashing, run to the car and press the desired homelink button (I in my case) twice. [THIS IS TIME SENSITIVE so be fast]
Step 7: If it Dint start working immediately, push the same button twice a few more times until the door starts to move.
Step 8 (Optional): Cry with happiness on learning to do this after 15 months of owning car :P
This sounds more like the procedure in the manual which should always be tried/followed first.
The LED bulbs in my opener are screwing with the signal from my Homelink. Just been too lazy to swap them out. I was wondering why it worked fine to open the door but not close it.
Club AutoUnion
As always, YMMV.
— John
I have (4) Cree LED bulbs between the (2) LiftMaster 8550W operators in our garage. Never had a problem with either the LiftMaster remotes or the Audi & Acura built in controls. Installer was shocked to see that when he installed the operators several years ago as he had problematic experience with LED bulbs in other installations. Cree has always been my go to brand for LED bulbs.
