2022 Radio “initializes” every few days
This is happening in my MY22 Q5, along with losing car settings like mirrors folding up, etc. The MIB3 MMI is just pretty atrocious overall; touchscreen, functionality and stability with the web service/cloud implementation. Makes me want to keep my B9 A5 SB MIB MMI for just about ever...or maybe until MIB4, if it improves anything.
Nikon1 (02-13-2022)
As someone said, you might need a software update. However, not sure if you can get it over-the-air or if that is a dealer-thing. Good thing is, either way ... it should be free or cheap.
Has anyone had this apparently random "reset" happed to the hatch setting on their Sportback? The ceiling in my garage is kind of low and if the garage door is rolled up the overhead clearance is even less. So, I have the limit set on the rear hatch to stop about 3 inches below where the garage door sits when in the up position. I'm concerned that at some point the car will reset and that memory setting gets lost and the hatch is going to smash into door or ceiling.
However, you might want to install some strategically-placed foam on garage door just-in-case. Back when we had the MDX, I attached some small pieces of pipe-insulation, just in case someone accidentally pressed the wrong key-fob button and the hatch tried to open while the garage door was still closed. It just bounces-off and closes with no scratches. Same principle.
Has never reset on our Q5-e (and never happened on Acura MDX either).
Scottish_A8_4.2TDi
Q7 MK 1 Discussion
04-20-2007 04:29 PM
BeaksNFlippers
04-20-2005 07:05 PM
