Apple CarPlay Question
Hi folks,
Been enjoying my A5 Sportback for a couple of weeks, but identified a pretty annoying issue about CarPlay:
Say I enter the car, start the car, plug in and connect the CarPlay, the MMI displays my phone's interface, all good. Now I start backing out, MMI switches to camera, and once I finish backing out and start driving, MMI switches back to main menu, not CarPlay! To make it worse, when I try to hit the CarPay option from the main menu, the display flicks but won't enter the CarPlay interface. I have to either re-plug my phone or re-connect in connection manager.
Anyone has similar situation? Or any thoughts? Pretty minor, but it's annoying because you want to set everything up and drive, instead of having to set it up again after you are on the road already.
Hope it makes sense. Thanks a lot folks.
hmm....you are luckier than me haha. ever since I noticed that, i've had it happen every single time....don't know which one, Audi or Apple, can fix it.
good to know! It would be a lot easier if the issue comes from Apple, and they hopefully can fix it on their upcoming updates. Thanks for chiming in with the info!
I use Android Auto every day multiple times and if on the AA screen and rear camera engages it goes back to the AA screen. I'm assuming it should work the same way with Car play. Doesn't make sense for it to go to main menu.
Exactly. But from the comments above looks like it's more of an Apple issue, and your Android working just fine shows that Audi MMI is not to blame. I guess I will just wait for Apple to fix it then.
Just kidding.
You might check out a few apple forums and see if others are claiming the same issue from other auto manufacturers. Don't let Apple off that easy and wait, make them aware that they have an issue.
