Auto Hold Button Installation
#181
I have all the wiring in place ad in OBDeleven have set bit 6 of 09-Central Electronics to 1
Do both bytes in the 03-ABS setting need to be be changed before being saved? If I try to save the Byte 18 change before making the Byte 30 change, I get an error "(31) Function not available" in OBeleven.
Paul
Paul
#182
Presto... works perfectly
When the Autohold is activated, lifting your foot off the brake pedal restarts the engine.
Noticed this "PARK" inducation on the dash when active (above the VC area).
#183
Club AutoUnion
Reviving an old thread — maybe some of the Newer Members are not aware of this aftermarket solution — I ordered the Kufatec Kit last week and it arrived today. With this installed and enabled, when your car comes to a complete stop, you can remove your foot from the brake and the car stays stationary, with the brake lights on. Enabling the e-brake will not leave the brake lights on (potential safety hazard). When you’re ready to go, tapping the gas pedal will remove the brakes and you’re off again.
What do you get for approximately $175 (at last weeks exchange rate) in the kit?
Genuine VW / Audi Switch that mounts in the console
Complete Wiring Harness (Kufatec Assembled & Tested)
Kufatec OBD Auto-Feature Programming Dongle
Once your order is accepted you will receive an e-mail link that allows you to download the 19 page Installation Guide, which has all the steps necessary to install the new switch and wiring harness and then plug in the feature programming dongle that makes the Audi programming automatic.
If you read through this thread, you’ll see various posts about what exactly this kit provides as well as some step-by-step instructions.
NOTE: There are two different kits discussed within this thread. This kit requires soldering a wire in the installation, but no need for a VAG-COM or OBD Eleven to software code the features. The other kit, 4Rungs requires no soldering but does require a programming tool to enable the software coding. Pick Your Poison.
Due to some scheduling, I will not be installing mine for about 2 weeks but I will update this thread when it’s installed.
— John
— John
#185
— John
— John
#186
Club AutoUnion
And, to add to your thoughts, there seemed to be some “drama” around the 4Rings company, not the product. Kufatec is a well known and respected manufacturer / vendor, so that really made my choice for me.
As always — YMMV.
— John
As always — YMMV.
— John
#187
Thanks for the info. Can you include the link to the product page? Apologies if I missed this. I have this in one of my other cars and it is a "nice to have".
#188
Agreed Kufatec is the way to go. It's the soldering that worries me. I haven't in a long, long time.
#189
Club AutoUnion
Kufatec Auto Hold Button
— John
exmeaguy (06-17-2020)
#190
Club AutoUnion
