When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I couldn't see the scratch however, if it isn't too deep and only in the clear coat then you should be able to polish it out just like the surface of a car.
I can see why you'd want to wrap it because the carbon fiber trim pieces are so expensive, almost $800 for just the small door trim pieces and about $400 for the two dash pieces. I can't imagine wrapping it would look as good, of course it would cost a lot more though. Although it's expensive, it's not expensive enough for me to not buy them, although I considering leaving the aluminum trim on the doors since the carbon fiber has an aluminum edge. I did the center console, $255, and will do the dash next once I'm a little more comfortable with how to remove the dash trim. Any advice or info on removing the dash trim?
