R1234yf Question!
Hello all had to replace an ac line in my 2018 S5 Sportback and long story short got the adapters for the r1234yf refrigerant to fill Freon back up and was wondering if our systems are anyway compatible with the old r134a? I know Mercedes had a whole thing with recalling the new Freon and just filling their cars back up with the old stuff to be able to be sold again. Can someone chime in on this and let me know if I’m completely misinformed lol. Thanks!
Theoretically the R1234yf nipples won't allow a 134A female adapter...you'd have to use the R1234yf female quick connects on hose to a manifold and then load the manifold from a can of R134A. There are also issues with the oil used in the R1234yf system that may not play nice with R134a.
For reference, MB DID a recall of some 400 vehicles in 2012 to replace the flammable R1234yf with R134a due to fire hazard in collision but it was a specific exception. I suspect it could be done with your system, but it would involve evacuation, replacing dryer/filter/if not expansion device, as well as draining/flushing/refilling the compressor with oil compatible with R134A and replacing the nipples/hoses that use an R1234yf nipple with nipples/hoses compatible with R134A fittings. And it would be a violation of the Clean Air Act.
https://static.nhtsa.gov/odi/rcl/201...2V478-9042.pdf
2018 S4
![](https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage/N3569/large/12001779_acj_certyf1024_pri_larg.jpg)
Not so easy, Johnny B. I bought this:
but, the r1234yf isn’t deep enough. I like the gauge, hose, and the can tap, so I’m keeping it. I decided to try again on the port connection with this:
I’ll find out…tomorrow!
Does anyone know what adapter / fitting to get?
