Rainex or similar for rear window on SB?
So, love the fact that rear window isn't cluttered by a windshield wiper, but of source would be nice to keep it clean!
I'm reluctant to put RainEx (or similar) on front windshield because of how wiper blades tend to mess it up over time. But the rear window seems tailor made for some treatment!
Anyone using anything? Any recommendations on what to use?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
From my experience, there isn't any one product that solves the problem. My glass has Ceramic Pro coating -- which is 1000x better than RainX or other off-the-shelf products -- and yet water beads still just sit on the glass. It's better, because there's no sheeting (as there was prior to CP), but the beads don't actively run off ... the glass is at just the right angle to hold it.
I use RainX on all windows and rear windshield, feels 100x better compared to no coating. Visibility is still low at low speeds though.
Applied on front windshield and regretted!!!
It flares bright lights (on-coming vehicles), in precisely the conditions you need maximum visibility, such as at night in rain. Not just drivers' eyes, but can affect the efficacy of the camera mounted behind the rear view mirror. You don't list your location, but if you have Matrix lights, this flaring can affect their operation, and may have a similar affect on low speed autonomous braking systems (as used in Audi City). The B9 user manuals specifically warn not to use these type of products on windscreens.
I use Rain-X on all of my cars, motorcycle helmet and windscreen of my helicopters. The initial applications take more work, but once a solid coating is established correctly, I only need to reapply twice a year. I use the concentrate on the initial application after I have thoroughly scrubbed the windscreen with ammonia free glass cleaner followed by a 20% alcohol to water mix. Then i apply four coats of Rain-X on all the glass. The haze (which produces the flaring or "halo" of on coming cars at night) is the only trouble, but if parked in the shade, two hours after application, I take a micro fiber cloth on a buffing wheel to the glass. Buffing the haze off properly eliminates all issues at night. I also use the Rain-X windscreen washer fluid to extend the life of the initial application. The treatment results are best noticed at night. I get no headlight haze or issues and night driving in the rain is a complete non-issue. Many times, I don't even use the wipers.
The real trouble is the lack of airflow over the rear window to move the water and dust from the surface. As the air moves across the roof of the car, there needs to be a device to direct air across the surface. These devices tend to be rather unsightly on sedans, so we live with it and stop often to get gas and wash the window off. I'm extremely type "A", so i have an all in one spray bottle with sponge and squeegee in my trunk. It is filled with the Rain-X windshield washer.
These are my results, but again...I'm extremely type "A".
Mark90
06-19-2014 01:22 AM
LavaA3
12-20-2004 10:48 AM
neTTwiz
07-09-2001 07:36 AM
