Replacement Tire Question
Hi there,
So, unfortunately a few weeks ago, I blew a tire on my 3 month old A5 SB. My tires are 19in stock ContiSport Contact 5P - 255/35/R19. When I went to the dealership with the car, they thankfully said I didn't have to replace all 4 tires, given that I had very low mileage and barely used any tread. I was washing my car last night, and noticed the tire they put on is the same ContiSport Contact 5P, but it's a 255/35/ZR 19. As far as I can tell, they have the same speed rating (96Y) - both tires are marked with 96Y, but the one that shows the "Z" has that written in brackets and the other ones don't. No other differences on the tire itself.
I have no idea what, if anything this means for the tires? Any insight would be much appreciated.
Thanks!
Thanks!
From Tire Rack:
When Z-speed rated tires were first introduced, they were thought to reflect the highest tire speed rating that would ever be required, in excess of 240 km/h or 149 mph. While Z-speed rated tires are capable of speeds in excess of 149 mph, how far above 149 mph was not identified. That ultimately caused the automotive industry to add W- and Y-speed ratings to identify the tires that meet the needs of vehicles that have extremely high top-speed capabilities.
Your car should be fine. Audi service centers do not install parts that are not tied to your car's VIN#. Any parts they order must correspond to your car's VIN# and they follow what the system tells them to do. For further assurance, look for the 'AO' mark on the tire sidewall. 'AO' means it is the Audi factory spec tire. But, even if it does not bear the 'AO' mark, it is still OK as long as the size, speed/load rating, brand/model, and tread depth are the same.
Your tyre will have production location info on the sidewall. It also will have the date of production, which is worth checking on a 5P as that has been in production for several years. New old stock is not a good thing for tyres, the compound hardens with age. Agree with Plat, you'll be fine with a dealer supplied tyre.
royals1982
11-15-2009 11:18 AM
f4eye
10-22-2003 02:57 PM
